Planning to change 4AT transmission fluid, what do I need?
Old 09-24-2006, 01:37 AM
fickiemickie's Avatar
I want to change the transmission fluid on my 2005 AT RX-8 to Royal Purple ATF and the differential fluid as well. How many quarts will I need to buy. Are there any special parts/tools I need to get? Is the procedure the same as the manual transmission cars (https://www.rx8club.com/series-i-do-yourself-forum-73/diy-transmission-differential-fluid-replacement-35115/)?
Old 09-24-2006, 01:49 AM
it is not close to the same, and some issues have happened with the wrong syn atf fluid.....
i would stay with what the maual says. and do a lot of research....
good luck..
Originally Posted by fickiemickie
I want to change the transmission fluid on my 2005 AT RX-8 to Royal Purple ATF and the differential fluid as well. How many quarts will I need to buy. Are there any special parts/tools I need to get? Is the procedure the same as the manual transmission cars (https://www.rx8club.com/showthread.php?t=35115)?
Old 10-11-2006, 11:05 PM
I4NI
Silver_Surfer's Avatar
I flush mine out with Redline ATF where I work. Used about 12qts.
Thought about dropping my pan but the torque converter & lines would'nt drain out so opted for the flush.
Old 10-11-2006, 11:54 PM
sosonic's Avatar
I use Redline too. It takes a lot to replace all the ATF, about 12 quarts is right. If you only do/get 4 or 5 quarts than you have not done a complete drain and replacement.
DJclever
09-06-2015 10:51 PM
T_Mags
09-03-2015 11:40 AM
Zank300
08-26-2015 07:40 PM
CRAZ8
07-22-2015 10:02 AM
Quick Reply: Planning to change 4AT transmission fluid, what do I need?
