Installing Stock Nav System In An Rx8
Old 07-25-2006, 03:33 PM
I LOVE MY RX8 =]
RX8GIRL05's Avatar
Question Installing Stock Nav System In An Rx8
is it possible to install the stock nav system to my rx-8 if it doesn't already have one in there? i have a portable one, but i want the original nav system. thanks !
Old 07-25-2006, 03:36 PM
NgoRX8's Avatar
one person here has done it. it is honestly a lot of work and costs more than the stock navi option too. not really worth it.
Old 07-25-2006, 03:39 PM
I LOVE MY RX8 =]
RX8GIRL05's Avatar
hm, i see. okay thanks. is there any other suggestions you might have to installing one or are my choices pretty much slim to none because the whole cd unit isn't made for anything aftermarket? unless of course if i use one of those kits, but i hear they disable some other things .. like the AC and hazard lights.
Old 07-25-2006, 04:06 PM
NgoRX8's Avatar
if you want a screen to pop up like the navi, then there is no alternative to it right now. if you want to get one of the built in computers for the unit, it is quite expensive as well, but i've only heard of the steering wheel controls not working. most people have simply gone with a computer placed on the head unit where the stock navi is suppose to go. then again, everyone can see it's there because it is out in the open.
Old 07-25-2006, 04:12 PM
I LOVE MY RX8 =]
RX8GIRL05's Avatar
yeah .. too bad mazda made aftermarket electronics so impossible =(
Old 07-25-2006, 04:25 PM
He's as bad as Can
expo1's Avatar
Yep, https://www.rx8club.com/series-i-do-yourself-forum-73/diy-whole-navigation-system-59957/
Old 07-26-2006, 02:21 AM
Flashpoint Racing
MSTYLES's Avatar
It's actually not as bad as you think. I have been able to find 2 factory NAV systems out of wrecked 8's. I got them for under $250 each....just pay someone to install it. There are other options but the factory flip screen is the bomb!!!
Here is mine....
https://www.rx8club.com/showthread.p...3&page=1&pp=15
Old 07-26-2006, 02:29 AM
Can I change my username?
maybeashinka?'s Avatar
just make a hole in your dash, stick the Lilliput flip up screen into it. boom done. connect a pc to it, download a gps program thru bit torrent, save some money, done again
Old 07-26-2006, 03:46 AM
^NieL
N rider89's Avatar
Here is mine....
damn you found two and for 250 if you ever want to sell one..... im here
Old 07-26-2006, 05:52 PM
I LOVE MY RX8 =]
RX8GIRL05's Avatar
haha .. thanks everyone !
Old 07-26-2006, 05:54 PM
I LOVE MY RX8 =]
RX8GIRL05's Avatar
Here is mine....
wow -- niceeee car. i have a black rx-8 too, but dang yours is clean =)
Old 07-26-2006, 09:25 PM
if your not 1st your last
Kel Rx8's Avatar
honestly the stock navi sucks, its got okay features and flip is okay
but has got me lost several times even with the latest updates.
Old 07-26-2006, 11:07 PM
I LOVE MY RX8 =]
RX8GIRL05's Avatar
yeah, i heard it sucks. i mainly just want the ability to have a navigation system in there other than my portable one, and i wouldn't mind having dvd and everything too.
Old 07-26-2006, 11:45 PM
Kel Rx8's Avatar
I hear ya
but I rather get a unit installed in the place where the headunit is. there are a bunch of good units out there like alpine and pioneer cheaper and easier to install.
Old 07-27-2006, 11:16 PM
Int'l Man of Mystery
Japan8's Avatar
My suggestion...
Do some searching and snag the stock nav dash panel from a salvage yard. Do some research on places like http://www.mp3car.com and build a car computer. You can get nav, mp3s, DVD, Divx, internet, bluetooth phone and more. To be honest... it is getting easier and easier to do if you want a Windows Xp based system. Here's a short breakdown...
monitor- Pickup a 7" LCD VGA monitor, remove from case and install the LCD panel in place of the stock mazda one in the nav dash panel.
CPU - depends on your preference and budget. A new VIA EPIA SP 13000 or MII 13000 would be enough to do what you need. Pair it up with a VroomPC case or a 1DIN sized case (to mount in the console where the stock NAV CPU mounts).
Software - Windows XP and add a "front end"... packaged commercial ones like Centrafuse and Streetdeck will be the easiest to install, likely have fewer "quirks" and both come with navigation software integrated. RoadRunner and Frodoplayer are two very popular front ends, but will probably require a bit more technical knowledge to get them running.
Additional hardware - GPS "mouse" receiver, automotive power supply, and "Car2PC adapater" and P.I.E. adapater. The Car2PC and P.I.E adapters together will connect the audio from your PC to the stock Mazda headunit and also allow you to control your PC via the stock steering wheel controls.
Total cost should run you around $1,000 - $,2000 depending on what hardware and software setup you go with.
Old 07-28-2006, 07:06 AM
LostAngel's Avatar
Japan8 is correct:
BTW: It's going to cost me around $1800 total for my CarPC (OEM Housing, Xenarc 7" TouchScreen, and actual PC. Chances are i'll be mounting the PC in the glove compartment for easy access and easy installation...but theres a chance that I'll put the PC in the trunk...I just don't want to run the wires!
Old 02-18-2008, 08:16 AM
darkest_sunrise's Avatar
Here is mine....
hi, i got a nav system for about as much, but was wondering what im looking at for installation? how much was it for you? thanks.
Old 02-18-2008, 09:14 AM
Registered Zoom Zoomer
Huey52's Avatar
You could buy four top of the line Garmin GPS's for the price of a dealer installed nav, and they have far more up to date software. And you can take your Garmin with you on trips or move it to other vehicles.
Not as esthetically pleasing perhaps as a pop-up built in, but definitely an alternative to consider.
Old 01-13-2018, 12:43 PM
Skweller's Avatar
Originally Posted by Kel Rx8
I hear ya
hi I've got the stock sat nav it's stuck on the caution!! Distraction may cause accidents screen with agree bottom right and a 🌎In the bottom left !!
The joy stick moves it from world to agree but nothing else any ideas
Old 01-19-2018, 09:04 PM
Kat6RX8's Avatar
Can I just swap out a Salvaged Nav unit from A 2009 RX8 to my Regular DVD unit that came with my 2009 Touring unit?
SUKIEE
10-09-2017 09:41 PM
RXeckless
08-16-2015 12:52 PM
akagc
08-11-2015 07:07 PM
CMRine04
07-27-2015 09:46 PM
AussieGray
07-16-2015 03:58 AM
Quick Reply: Installing Stock Nav System In An Rx8
