Rear Oxygen Sensor specifications (avoid cat cel) ???
Old 04-25-2006, 02:17 PM
florent75's Avatar
Hi,
I'm looking for the rear Oxygen Sensor specifications :
after the catalytic converter
it gives the A/F (Air Fuel Ratio) and good or bad catalytic converter
it detects the oxygen concentration in the exhaust gas
a high voltage --> car rich (<14,7 AFR)
a low voltage --> car lean (>14,7 AFR)
with model ??? LM1 ?? bosh ???
I know :
- it's a 4 wire sensor :
[C] [A]
[D] [B]
where :
A : Y (Yellow)
B : BR (Brown)
C : W/R (White / Red)
D : R (Red)
- when you check the voltage ; at 3000 rpm should should have 0,5- 0,7 V ; under accelerated you should have 0,5-1,0 V and under decelerated : 0-0,5 V
take + to A and - to B --> Voltage
- you should have a 14,1-18,9 Ohms resistance under 68°F (20°C) : conditions for the sensor to work fine
take C and D --> ohms
anybody check the voltage after putting a midpipe ???
By putting the correct resistance you can perhaps avoid the cat cel ?????
need some help
thanks
Old 04-25-2006, 02:58 PM
Fraid it's not that simple. The PCM does a test cycle...and it expects both sensors to react in a certain manner. Since the WB02 is current based...and the narrow band...voltage based...you will have a devil of a time fooling it.
Old 04-25-2006, 03:31 PM
florent75's Avatar
humm .... could you be more explicit ??
if I stay with a voltage between 0 and 1V and close to 0,5V at 3000 rpm .... should be right ???
I will test an electronic fooler for subaru sti and mitsubishi evo VIII (a friend of me build them ... ; it's perhaps the same)
and I ask GTAW too for his fooler ..
Old 04-25-2006, 04:00 PM
StealthTL's Avatar
Arrow It ain't no Evo.....
The output the sensor sends is "spikes" or clicks of voltage, increasing in frequency as the mixture gets leaner.
So you would need a fooler circuit that sends regular pulses, like the ones they use to fool Subies and Mitsus, but when the ECU sends a check of rich/lean mixture, it expects both sensors to react, and no fooler ever could.
S
Old 04-25-2006, 04:07 PM
florent75's Avatar
so perhaps it will works ... perhaps not ??
I 've seen caster eletronics selle an electronic fooler ...
is it working or not ?????
Old 04-25-2006, 04:22 PM
No respecter of malarkey
Received 2,007 Likes on 1,636 Posts
it can be done, but it will require monitoring the front sensor and then outputing an electronic signal back to the PCM, not going to be cheap, at least not initially ...
Old 04-25-2006, 04:43 PM
florent75's Avatar
I read here some use the casper electronics 104052 fooler
some say it's well working
other it's not working (or only working with a high flow cat and not a midpipe ...)
who is true ????
and ... it's the same fooler for the evo VIII on the casper eltronics website
Old 07-05-2007, 07:42 PM
2005 Ti Gray RX-8 - SOLD
Chamberlin's Avatar
and some good reading here:
http://www.aa1car.com/library/p0420_dtc.htm
Audio Concepts ATL
09-26-2021 01:59 PM
ladnarf1
04-29-2021 11:53 PM
tbiggybig
08-13-2016 06:30 PM
LiveWire
General Automotive
11-16-2015 11:41 PM
Jvswan
28
07-23-2015 09:02 AM
Quick Reply: Rear Oxygen Sensor specifications (avoid cat cel) ???
