transmission fluid change
Old 02-15-2006, 10:42 AM
cgseanp's Avatar
Hey everyone, I have a quick question about getting my tranny oil changed. I did a search but couldn’t find the answer I was looking for.
So my car has been shifting not so smooth lately, I want to try some Redline or Royal Purple fluid. I called a transmission place today and the guy said something about me needing 12 quarts? I think he was going to completely flush it out.
I don’t need it completely flushed out, do I? How many quarts of oil should I bring?
Thanks for your time.
Old 02-15-2006, 11:50 AM
StealthTL's Avatar
Auto?
It must be an automatic, right?
12 quarts of Redline is overkill! I would just use good name-brand tranny juice.
S
Old 02-15-2006, 11:53 AM
Punksux's Avatar
mazda swapped it out for me and only used 2 quarts of the transmission fluid and 2 quarts of the differential both redline. You can look at the car manual and i believe one is 1.4L in size and the other is 1.7L. assuming the car is a stick
Old 02-15-2006, 12:12 PM
Ole Spiff's Avatar
12 quarts is absurd. You don't need it flushed out; just drain the oil that's in there and replace it.
I replaced my manual trans fluid with Royal Purple and it required just over 2 qts; get 3 bottles and that will cover it just fine. The rear differential requires just under 2 qts so if you want to replace both, get 5 bottles and that will take care of it.
Old 02-15-2006, 12:55 PM
cgseanp's Avatar
thanks for the replies. my car is a manual. When you take your car somewhere to have the tranny fluid changed, do they automatically do the differential as well?
thanks.
Old 02-15-2006, 01:25 PM
Go48's Avatar
thanks.
No.
Old 02-15-2006, 01:33 PM
cgseanp's Avatar
Originally Posted by Go48
No.
ohh. Sorry if this is a dumb question, but do both the tranny and differential use the same oil? is 75W90 the correct grade of oil? I was looking at redline online, and they have the 75w90 and the MTL.. I'm confused as to what I should buy.
thanks for the help
Old 02-15-2006, 01:41 PM
Go48's Avatar
You need to make sure that the differential oil is suitable for a limited slip differential, assuming you have the 6-speed manual GT version of the car.
Old 02-15-2006, 01:47 PM
Rotary only since 1980
Blue87Sport's Avatar
Check out the DIY thread https://www.rx8club.com/series-i-do-yourself-forum-73/diy-transmission-differential-fluid-replacement-35115/
Post 46 shows what to get.
02-27-2020 08:39 AM
02-10-2020 10:23 PM
Mane
11-20-2015 12:16 PM
vapor2
09-21-2015 01:36 AM
Anthony Kevin
09-07-2015 07:36 PM
Quick Reply: transmission fluid change
