Car alarm problems
Old 11-28-2005, 10:19 AM
cgseanp's Avatar
Car alarm problems
Ever since I have had my car, I have had to be pretty close to my car for the alarm clicker to work.. (about 10 feet or so).. well, this morning, it wouldnt work at all from any distance... it took me about 20clicks to get my car to unlock.. so when i got to work, i locked my car with it, and it worked better, but when the horn honked, it was very faint.. so I assume the power source is dying and I have a feeling when I get to my car after work its not going to open at all
Does the alarm run off the car battery? My car had no problems starting up this morning so it seems like my battery has a good charge. If the clicker wont work, is there any way I can disarm the alarm so I can actually start my car up? I know i can just unlock my car with my key, but i dont think I can start it up..
thanks!
oh and this morning I unarmed hte alarm when i left and just locked the car by hand.. does the car alarm arm itself?
Old 11-28-2005, 11:47 AM
Registered Rep
JonsToy's Avatar
I'd check the battery in the key fob. Sounds like it's running low on power.
The alarm runs off the car's battery, but your key fob has its own battery.
And yes, the alarm will arm if the car is locked by either key fob, key in lock or lock switch in door.
Old 11-28-2005, 12:02 PM
cgseanp's Avatar
I thought about the battery in the clicker, but that wouldnt explain why when i arm the alarm, the horn honk is really faint as compared to usual.. i hope my battery isnt dead when i leave work
Dokuji
11-01-2016 02:51 PM
RXeckless
08-16-2015 12:52 PM
Str8lineJKing
07-22-2015 04:19 PM
Jmanie9515
07-20-2015 07:29 PM
Belalnabi
07-17-2015 07:48 PM
Quick Reply: Car alarm problems
