What would cause my compressor to cycle with A?C off
Old 10-28-2005, 09:11 AM
MDRX8's Avatar
What would cause my compressor to cycle with A?C off. It just does it with the fan in th on position. When you turn the fan off it quites? (three a/c amps and tree control panels later). THANKS
Old 10-28-2005, 09:14 AM
Momentum Keeps Me Going
Spin9k's Avatar
AC is on by default with (even heat) airflow to the footwell area (stange and inexplicable, but true) Look at your little pictorial of airflow.
Old 10-28-2005, 09:21 AM
StealthTL's Avatar
Dehumidifier......
Spin has it right, the manual spells it out - the a/c cuts in to dehumidify the air whenever ANY setting other than "dash" is selected, and it doesn't light the indicator!
The straight arrow dash setting is the only sure way to keep it off.
I'm in the far north, I pull the fuse marked "a/c clutch", 10 amp. That way the computer thinks it is still controlling the a/c.
S
Old 10-28-2005, 10:11 AM
MDRX8's Avatar
Crazy way
That is a crazy set up. Most cars don't do that. Eats up your gas mileage.
Thanks guys
Old 10-28-2005, 11:17 AM
Rexella's Daddy
Gerael's Avatar
when does it kick in? timer based or temp based? or humidity index?
and why is off only when in the dash position??
Old 10-28-2005, 12:42 PM
Thanks guys
actually most cars do have a scheme to have the ac on whenever the defroster is on.
and in the case o fthe rx-8 wheneve floor is selected defrost is also automatically selected. that has to do with placement of the heater core,ac condensor and the path of the vents in relation to the widshield because of the engine being so far under the A-pillar line.
Old 10-28-2005, 07:08 PM
Lubricious
Nubo's Avatar
The only selector setting that does not trigger AC is the full-face position.
Old 10-28-2005, 08:39 PM
Obake no Q-chan
Q-chan's Avatar
Hello MAZDA - are you listening?
It would be a *GREAT* update for PCM programming to allow the driver controll over the A/C for any setting,
except explicit Defrost.
Thanks in advance,
Q-chan
(which flash will contain this?)
Old 10-28-2005, 09:27 PM
none zero zilch not ever goign to happen. its like that for a reason.
02-10-2020 10:23 PM
OnebaddRx8
08-25-2019 11:34 PM
Digitz0070
55
07-25-2017 08:40 PM
stickmantijuana
10
09-13-2015 11:28 PM
RAE008
09-12-2015 09:08 PM
Rate This Thread
Quick Reply: What would cause my compressor to cycle with A?C off
