Camcorder Mount?
Old 05-05-2005, 09:30 AM
laser88's Avatar
Smile Camcorder Mount?
Hey All,
How do you mount a camcorder/digital camera behind your front seat in the 8 in order to get a video of your drive? I mounted the camcorder on a tripod stand and put it behind the seat, but the camera shook too much during the drive and the video came out bad/real shaky.
I'm not quite sure on the best way to do this so I need your help with suggestions. I'm quite certain many of you have done this already.
Thanks for your help!!
Old 05-05-2005, 10:32 AM
StealthTL's Avatar
Two holes......
Take out Pass thru.
Drill two bolts into metal of rear deck.
Drill two matching holes in 1" square tubing.
Drill quarter inch hole for std. cam mount bolt on front of tubing.
When installed, mount sits just behind front seats, with good field of view.
No fuss, solid, and steady.
S
Old 05-05-2005, 11:08 AM
Go48's Avatar
Originally Posted by laser88
Hey All,
Check out the DIY section. I'm pretty sure there is at least one approach that is thoroughly documented.
Old 05-05-2005, 09:26 PM
Momentum Keeps Me Going
Spin9k's Avatar
I have a solution I use for camera mounting. Goto my mods section at www.spin9k.com - so far it has worked well at track this spring. PM me for details.
Old 05-05-2005, 09:45 PM
Zaku-8's Avatar
www.chasecam.com for a non-diy option
Old 05-05-2005, 09:48 PM
SilverEIGHT's Avatar
Yea, the chasecam is what I bought. Works OK for small cameras and you can put it anywhere on your car (glass/body) even outside. I would strap it on though. I bought the twin triple suction cup model.
Old 05-05-2005, 10:01 PM
Certified track junky!!!
Speed Racer's Avatar
I've got both a Chase Cam and SpinMount. Both are good but they suit different purposes. The Chase Cam has a much wider angle of view and when mounted low to the ground (i.e. under the front bumper) it gives a nice sense of speed with the road rushing by at mach one. The down side is that all of the action seems too far away. You practically have to be a car length behind the person in front of you to see them well. It took me a while to find some replacement lenses but I have had a hard time getting them to focus properly.
Where as the SpinMount holds a normal camcorder just behind the front seats. From that position it allows the camera to see a good portion of the interior. Which I think helps people identify what you are driving. The angle of view also gives a better sense of the action with regards to traffic. The only problems I've run into are camcorder related. Some times the auto brightness gets confused. The end result is a great shot of the interior of the car but the world outside of the windshield is a complete white out.
Old 05-05-2005, 10:53 PM
StealthTL's Avatar
Elegant.....
Simple, solid, adjustable.
Change the elevation by using more/less washers under the wing-nuts.
Elegant?....no.
Elegant in it's simplicity?.....and cheap too!
S :D
Old 05-05-2005, 10:56 PM
Registered Tracker
BlueRenesis82's Avatar
Did the same thing as stealth but with a wooden dowel into that little compartment. No vibration at all, unless im in the rumble strips
02-20-2019 05:16 PM
05rx8mazda
11-28-2015 09:42 AM
ShellDude
10-01-2015 09:55 PM
pjwermuth
09-28-2015 11:36 PM
Series I Do It Yourself Forum
09-06-2015 01:04 PM
Quick Reply: Camcorder Mount?
