DIY: Easy removal of the air filter box
Old 04-30-2006, 11:06 PM
  #26
WedsSport Member
R888's Avatar
there is, from 5rpm
Old 07-26-2006, 10:23 PM
  #27
OnRails's Avatar
Originally Posted by COACHHARPER
I HAVE ALL THE DISK AND INFO SHEETS TO MY RX8, AND I SPENT TWO HOURS SEARCHING FOR A SHORT CUT OR A SIMPLE WAY TO REMOVE THE AIR BOX HOUSING. LMAO, I READ THIS ARTICLE AND REMOVE MY BOW LESS THAN A MINUTE.
THAnk you from coachharpr@hotmail.com
Is Coach Harper someone famous?
Old 10-07-2006, 12:02 PM
  #28
calaloco's Avatar
Do Revi intake kit & ram air duct fit 2006 RX-8?
Thanks.
Old 10-09-2006, 04:47 PM
  #29
always filling [the c]up
Cody Red's Avatar
Thanks.
they should. otherwise, racing beat would of said something, and most likely would of already made a separate system for the '06 model.
Old 05-09-2007, 02:55 PM
  #30
2005 Black RX-8 GT 6M
CarAndDriver's Avatar
This thread on the same subject is very helpful and it includes a good how-to video, where the person has an easier time than I just did.
https://www.rx8club.com/series-i-tech-garage-22/stock-air-filter-removal-73417/
Thumbs down on the design of this air filter box!
Here is a longer thread on impressions of the K&N drop in filter.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/impressions-k-n-panel-filter-82607/
Old 10-14-2007, 06:44 PM
  #31
I am a meat popcicle
TownDrunk's Avatar
Thanks Jaguar and Cesar for the description and the pics (respectively). Piece of cake.
Old 01-01-2008, 10:44 PM
  #32
I recruit for USMC.
the_Colombian's Avatar
thanks for this how to. Did mine in less than 5 min and took out the little walls inside the box. Noise it a bit louder with the green filter.
Old 01-05-2008, 12:50 PM
  #33
White is purdy...
onefatsurfer's Avatar
Thanks.. That's how it is.. the design isn't THAT stupid anymore...
Old 02-14-2008, 08:19 AM
  #34
spd33's Avatar
Originally Posted by rotarenvy
anyone else having trouble when replacing the airbox that the lower centre rubber grommet keeps falling out the bottom into the radiator fans?
it's really beginning to annoy me as each time I put the airbox back in it falls into the radiator and I have to take out the lower tray to fish the grommet back out
This is probably the single most important post in this thread! That grommet does not stay in like the rest and drops directly in to the fan.
Pay VERY close attention to it when you are pushing the box back in and feel around to make sure it is still there once the box is reinstalled! This just happened to me 2x in a row and I finally just left it out also. It is kind of a pain to fish it out but an 18" grabber tool worked for me (the type with the little prongs on the end that you open and close from the top).
Old 02-15-2008, 01:52 AM
  #35
sosonic's Avatar
Originally Posted by bxb40
I found that there is an useless plastic clip where the air box inlet gets pulled up. It looks like a little hook, no use in sight. I simply cut it and the air box now is so much easier to take out
So true about that little plastic hook. I cut it too.
Old 02-15-2008, 08:08 AM
  #36
spd33's Avatar
My useless plastic clip is holding a vacuum hose. Might be different on different models.
Old 02-15-2008, 03:13 PM
  #37
DSC is for Weiners
Tracker's Avatar
in continuing the OT nature of this part...
Originally Posted by zenmoused
Any of you guys with K&N filters feel any difference?
its louder..other than that, i dont notice much of a difference, i know there have been at least 2 different variants of the typhoon, the first ones (they look like a double width cone) are the ones that have been known to have an issue with idling, the newer generation was designed to correct that (filter in an inferted cone in a carbon fiber housing), it also comes with a heatsheild that mounts into the same area as to stock air box to try to keep the heated air from getting pulled back into the intake
that being said about the warranty issue, as has been said its really up to the dealer, when my motor failed (04 mt 18,000 miles) the first thing they did was try to blame it on the intake, through a combination of a mechanic who was cool, myself, and a father who was pretty irate over hearing about it (he was the one who had to give me the ride to the dealership) we ended up getting it taken care of under warranty, but it was alot of stress and hassle, over something that shouldnt have been. i go to the other dealership in town and i get compliments about how the car sounds with the new intake. and not a one issue with it being on there
hope some of that awnsered a few of your questions
Tracker
Old 04-08-2008, 08:37 AM
  #38
<3 Rotary
dothackRAVE's Avatar
This technique didn't work for me at all. In fact, I broke one of the posts, and it fell into the engine bay somewhere. I can't find it anymore. :\
Old 04-08-2008, 03:54 PM
  #39
Skinless's Avatar
That sucks. What were you doing when it broke? Pushing back to pop out the first two posts, or lifting to remove the lower two? I used this technique to remove my airbox this weekend and it worked great. Sorry to hear you had problems with it.
Old 04-09-2008, 06:54 AM
  #40
<3 Rotary
I was trying to push out the top two posts.
Old 04-20-2008, 04:43 PM
  #41
My <3 rotates.
Pink Flea's Avatar
can not get air filter box OFF!!!!
Old 04-20-2008, 05:10 PM
  #42
Go48's Avatar
Push back on the box hard. The accordion intake pipe will compress and the front pegs will pop out of the grommets. Make sure the lower grommets are in place when you reinstall the box.
Check out the video link in post #9 of the following thread:
https://www.rx8club.com/showthread.php?t=73417
Old 04-20-2008, 06:04 PM
  #43
My <3 rotates.
Pink Flea's Avatar
I guess Im too weak... I tried and I cant get it... I also have a messed up arm from a recent accident so that probably dosent help... I will just get my sweetie to do it :o)
Old 05-02-2008, 08:07 PM
  #44
Not Jeff Gordon
Gauge's Avatar
I took the top part of the box off to check the filter. Anyways now theres these two latches that I cant get snapped back, stole the pic to help point it out The box seems to open a tad it seems without those, car seems a little louder too.
Attached Thumbnails DIY: Easy removal of the air filter box-boxknob.jpg
Old 05-03-2008, 11:18 PM
  #45
One Shot One Kill
xsnipersgox's Avatar
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-stock-air-filter-box-144789/
Old 02-01-2009, 11:20 PM
  #46
Drummond Built
WTBRotary!'s Avatar
for my Drop in K&N i just barely got it open and shoved it in there... lol
Old 02-02-2009, 07:27 AM
  #47
kainis2k's Avatar
Originally Posted by FastRX8
Well, I just followed the directions on the first post in order to drop in the K&N filter.
They worked like a charm, but everyone want's pics, so here you go.
- Cesar -
Very Nice DIY, Thanks for the pictures and to the OP. Good to see we are getting more DIYs up on the forums to encourage owners to do things to their cars which make them more marketable. Keep up the good work!
Old 02-02-2009, 11:38 AM
  #48
skrubol's Avatar
Do this when it's warm out and it'll be easier.
Old 02-02-2009, 08:14 PM
  #49
Docj78's Avatar
This is definitely the lil' bastard that's keeping me from getting this sucker out. I'm thinking that I may snip this clip off too. I can't see how it's useful at all.
Old 02-08-2009, 07:53 PM
  #50
zooma's Avatar
Wow... how easy was that?
I used this method for the first time today. Can't believe I've been prying the accordian hose off for the last two years. Very easy, very convenient. Did not see the center grommet that seems to bedevil others. Only two upper and two lower gormmets. Upper driver side grommet came out when removing the box. Was there a design change that eliminated the center grommet or am I missing something?
Quick Reply: DIY: Easy removal of the air filter box
