Need ECU pin-out or wiring diagram.
Old 08-12-2004, 04:11 PM
TORacing's Avatar
I have the RX-8 tech service manual but I don't understand the wiring schematic. I'm trying to install the Apexi RSM and I need to know the location of the wire that tells the ECU speed, RPM, and a ground and IG power wires. I already tried to talk to Canzoomer. So if some could help me or explain the wiring diagram in better terms it would be alot of help.
Old 08-16-2004, 06:43 PM
VividRacing.com's Avatar
I called up the dealer and they faxed the 15 page print out over to me. Call your dealer and see if they will do this for you.
Old 08-16-2004, 06:55 PM
TORacing's Avatar
Thanks Vivid but if your refering to the tech service manual I already have it and just don't understand it, is that what you are talking about.
Old 08-16-2004, 10:18 PM
Careful, I bite!
DisneyDestroyer's Avatar
Dude, electrical can be REALLY BAD if you mess it up. If you don't understand the diagrams, I strongly advise you not to do the work. Clearly you already know this, because you're trying to gain more understanding. That's good, but I'd still say just take it to a car shop and have them install it. Plus, that way it's their fault if it's done wrong, so you aren't out all the money for a new ECU, wiring system, etc.
Kidracer (09-05-2019)
Old 08-17-2004, 12:55 AM
Omicron's Avatar
Here ya go: https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Danield97
09-30-2015 05:59 PM
jer2911
09-29-2015 06:37 PM
XianUnix
09-29-2015 03:48 PM
Learners_Permit
09-27-2015 07:38 PM
stickmantijuana
Rotary Swaps
11
09-24-2015 12:47 AM
Quick Reply: Need ECU pin-out or wiring diagram.
