before and after
Old 08-04-2004, 10:16 AM
LOUSINIT's Avatar
before and after
Well this old man finally decided to add the goodies. Front and rear aeros and front flaps , strakes..wow alot of money for these little things,does dress up though!! Have the interior night lights ,think i will pass on doing them myself. I don't get along well with wires. Body parts were easy installs though. Tried to post before and after ,not sur if it will work ,first time .
Attached Thumbnails before and after-dcp_0167-3-.jpg   before and after-dcp_0157-6-.jpg
Old 08-04-2004, 10:23 AM
if your not 1st your last
Kel Rx8's Avatar
very nice
post some better day time pixs when you can.
Old 08-04-2004, 10:50 AM
drsingle's Avatar
Looks really good Lousinit.
Can you go into more detail regarding the installation? Were the instructions provided easy to follow?
I'm planning to install the aeros and front air dam myself, probably next month.
Thanks,
David
Old 08-04-2004, 10:51 AM
DRIVEN
cgrx's Avatar
Looks good
clears side markers ASAP =)
Old 08-04-2004, 11:00 AM
FREE ADVICE!
Razpewton's Avatar
They let guys your age buy RX-8s? :D
Looks great... I agree that the clear sides would look good too, but I'm not shelling out $60 to $80 for two pieces of clear plastic, nor $150 for the front and rear rotary accents. THOSE SHOULD HAVE COME WITH THE CAR!
Your car looks blue in the picture, but awesome none-the-less.
Old 08-04-2004, 11:34 AM
LOUSINIT's Avatar
The Aeros were fairly easy , Basicly clip and tape strip, if you want to follow the directions to a tee ,they have you drilling holes in the body (not) Have to cut the rubber stone guard under the sill, a sharp razor knife handled that easily. The rear aero mud flaps LOL instructions had you taking the bumper off............. no need for that at all, the same tape strips are already on them and two screws. I checked a couple at the nearby dealer they are installed the same way,basicaly no drilled holes. It may not be the exact way but they are not going anywhere for sure. The Nordic Green has a very odd visual effect with sun and clouds , may look deep blue , flat green ..no flakes or black. i liked that part. Skipped the front aero , driveway would eat it up , clear corners are neaxt after the night lights get installed.
