New ACT flywheels.
Old 04-08-2004, 09:25 AM
darkducati's Avatar
New ACT flywheels.
Anyone try these yet? They are incredibly cheap! Chromoly steel with the couter weight included, street light-$349.95 and pro light-$399.95! That's a steal. And such a better design than the new UR flywheel. Any information?
Old 04-08-2004, 11:02 AM
mazdaexe's Avatar
any links?
Old 04-08-2004, 11:10 AM
Not so Super right now
Genom's Avatar
rotaryperformance.com has them listed.
Old 04-08-2004, 11:11 AM
darkducati's Avatar
http://www.rx7.com/store/rx8/rx8driv..._flywheel.html
Old 04-08-2004, 12:31 PM
sto16's Avatar
Question
Can someone explain me what is a flywheels and what does it do?
Please, Im not technical when it comes to mechanical.
Thanks!!!!
Simon.
Old 04-08-2004, 12:32 PM
davefzr's Avatar
How would this compare to the Mazdaspeed flywheel that I have heard good things about.
Old 04-08-2004, 12:42 PM
darkducati's Avatar
It is a bit lighter and cost nearly less than half the price of the Mazdaspeed unit.
Old 04-08-2004, 12:50 PM
mazdaexe's Avatar
I believe Chromoly is better than aluminum? stronger than aluminum?
irq9's Avatar
Thanks!!!!
Simon.
Simon,
I'm not sure this includes info on flywheels, but it's a start: http://auto.howstuffworks.com/transmission.htm
Old 04-08-2004, 12:58 PM
davefzr's Avatar
The phrase "slight compromise in drivability" kind of worries me since people who have the MS version have said that the drivability was compromised "somewhat". Meaning that they have to pay closer attention to starting in first gear than before. The non pro version seems like the way to go.
All except for someone to install it costing you 6 to 8 hours labor
Old 04-08-2004, 05:15 PM
darkducati's Avatar
That's what the lift at work is for! :D
Old 04-08-2004, 05:16 PM
Broke_Apex_Seal's Avatar
Doing a flywheel is a must on our cars. Dont listen to anyone unless you have driven an 8 with it. I did it and wish I did it sooner.
Old 04-08-2004, 05:37 PM
darkducati's Avatar
It is absolutely stronger. The problem I have with the UR flywheel however, is not that's it's alluminum, but the design. Where do you want the weight on a flywheel? As close to the inside as possible(in a perfect world of race tracks anyway). The UR flywheel does have the integrated counter balance, and that is really cool. The problem is that it's all the way out on the perimeter of the flywheel. The prolite flywheel however doesn't seem to have much of any metal on the outer edge, aside from that which is needed for the starter ring gear. I could be wrong, but I think the prolite flywheel will rev far quicker than the UR, even if the UR is lighter. This is why I will go with the ACT.
Old 04-08-2004, 09:59 PM
2-rotor slave
weepul's Avatar
Yeah I'm curious as to what that means as well. I had a Fidanza for my '96 Talon and removed the balance shafts. I noticed if I rev'd it and drove it past 3k rpm and slipped it into neutral real quick, the flywheel couldn't catch the revs and the engine would stall out. Maybe it's something like that?
Old 04-08-2004, 10:04 PM
Senor Carnegrande
BaronVonBigmeat's Avatar
Does anyone have any dyno or track numbers that show the before/after difference of an aftermarket flywheel on an 8?
Old 04-08-2004, 10:22 PM
mdawgx24's Avatar
I have the MS Flywheel. It takes a little getting used to -- I stalled a couple of times on the first ride out. But since then, no problems.
Actually, you can get the MS Flywheel from Rosenthal Mazda for $522 shipped. Of course, getting it installed is another matter.
Jeff
Old 04-08-2004, 10:23 PM
RX7store.net
Jason's Avatar
The ACT is a populoar upgrade on the RX-7. I have plenty of them in stock for $250 if anyone wants one. All you need it the counterweight.
Jason
www.rx8store.com
Old 04-08-2004, 10:40 PM
GeorgeH's Avatar
Thanks!!!!
Simon.
A flywheel adds rotating weight to the engine. Without a flywheel, several bad things would happen. First, it would be much harder to launch the car - it would stall very easily and you'd have to rev the car and slip the clutch on launch. Second, the revs would fall much quicker between shifts, making it very difficult to get smooth shifting.
It does other very important things as well, like aiding in the dynamic balancing and damping which helps to keep your motor in one piece.
The down side to a flywheel is that it adds rotating weight to the motor, which makes the overall car accelerate slower. Replacing the factory unit with a lighter flywheel makes the car more prone to stalls, but you will generally notice better acceleration, at least in first and second gear. This is a good thing for an '8 given their lack of torque from a stand still
I have one in my Miata and I love it. It was very easy to get used to. I hope to do one in my '8 as well.
Old 04-09-2004, 01:22 PM
unorthodox's Avatar
Hey guys... wanted to clear one thing up. All RX-7/8 flywheels have a counterweight, including the ACT unit. The counterbalance mass requirement is a fixed amount. The radius at which the weight is placed on the flywheel determines how much actual weight is applied for counterbalancing. The end result has to be the same no matter how you do it. So what this means is weather you put a smaller weight towards the outside of the flywheel (like ours) or a larger one towards the inside (like the ACT and Mazdaspeed unit), the counterbalancing effect is the same. Hope this helps!
02-27-2020 08:39 AM
OnebaddRx8
08-25-2019 11:34 PM
05rx8mazda
11-28-2015 09:42 AM
Digitz0070
10-07-2015 12:43 PM
GARCIAC951
09-10-2015 07:17 PM
Quick Reply: New ACT flywheels.
