Non-Rotary Swaps Engine Swap Forum
TF-Works LS2-swapped R3
Old 03-22-2013, 05:39 PM
TFWorks's Avatar
We thought you guys might like one of our latest project cars.
Check it out:
TF-Works Built LS2-swapped 2nd Gen RX8 R3:
-Mahle Flat Top Pistons -4cc, 1.314″ CH, ~10.5:1 CR
-Eagle I-Beam Rods 6.125″
-Melling High Volume Oil Pump
-JP Performance Double Roller Timing Chain
-Comp Cams LSR “TF-Works Custom Cut” 235/243 .621/.624 113 LSA
-Comp Cams Hi-Tech Chromoly 3/8″ Pushrods
-Comp Cams Dual Valve Springs w/ Titanium Retainers
-ARP Head Studs
-Harland Sharp 1.7 Roller Rockers
-Trick Flow GenX 225 Heads
-Stainless Works 1 7/8″ Headers
-FAST LSX-R 102 Intake Manifold
-FAST 46# Injectors
-LS2 MAF
-LS2 Throttle Body
-VMAX 90mm Aluminum Inlet Ring
-LS9 Head Gaskets
-Full Hinson LSX Swap Kit
-Racing Beat Muffler
-TF-Works Flex Section
-TF-Works AN Lines to Stock Oil Coolers
-ACT Clutch & Flywheel
-Automatic FD3S Ring & Pinion Final Gear Set (3.91 Ratio)
-KAAZ 2-Way LSD
-Custom Driveshaft
-MGW Short Shifter
-Battery Trunk Relocation
-Completely Operational OEM Dash
-Custom-mounted GTO Pedal Utilizing LS2 Drive-by-wire
-WedsSports SA67R TSG
-Moton 3-Way Coilovers
-FD3S Automatic final drive , ring and pinion 3.91
As far as we know, this is the first LS-series swap into a second generation RX8. Be sure to keep an eye out during the 2013 season as this wolf in sheep’s clothing is scheduled to appear at road courses and drift events throughout the Midwest!
What do you guys think?
Old 03-22-2013, 05:45 PM
Car Dude
RadRedR3's Avatar
I think that's incredible. That's my ultimate plan for my son's R3. Verrrrry nice.
Old 03-22-2013, 05:46 PM
olddragger's Avatar
OOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!
Steering?
Old 03-22-2013, 05:50 PM
Now this is how you start an LS swap thread.
Old 03-22-2013, 05:53 PM
Chrishoky's Avatar
Final build price? Just curious...
Old 03-22-2013, 05:55 PM
TX
more than you want to know.
Old 03-22-2013, 06:03 PM
running on double cream!
rickeo's Avatar
Holy ****.
Old 03-22-2013, 06:31 PM
Moby's Avatar
Looks good! I feel like it's kind of a sleeper haha
Old 03-22-2013, 06:36 PM
Renesis out... REW in
firecran's Avatar
Car looks good other than the V8 under the hood!!!
J/k
It's F'in SWEET!!
Old 03-22-2013, 06:57 PM
Legend In My Own Mind
Mr_Pieper's Avatar
Needs more tire yo!
I bet it didn't take a year.
Old 03-22-2013, 07:13 PM
Supercharged by Pettit
NYC Drift King's Avatar
So sick. Clean swap!
Old 03-22-2013, 07:56 PM
Drummond Built
WTBRotary!'s Avatar
Whew... Intense... Not gonna lie...
Old 03-22-2013, 08:03 PM
The X is silent
RXeligion's Avatar
Impressive execution!
Old 03-22-2013, 09:36 PM
Is that a bike rack?
Lord ET's Avatar
Damn.
Old 03-22-2013, 10:24 PM
SuperCleanRx8's Avatar
Total cost? Nice and clean swap
Old 03-22-2013, 10:51 PM
New Rotary owner
lumiester123's Avatar
Touge Factory does it again!!
Old 03-23-2013, 01:04 AM
I HATE SPEEDBUMPS!
monchie's Avatar
Very nice indeed...
Old 03-23-2013, 05:13 AM
LifeAfterRx8's Avatar
Looks awesome. I usually hate v8 swaps but that looks so nice in there.
Old 03-23-2013, 06:23 AM
Voids warranties
godesshunter's Avatar
Slightly sad to see a transplanted R3. But you did an incredible job!
Old 03-23-2013, 07:30 AM
HiFlite999's Avatar
What did the weight and front/rear distribution come out to be?
Old 03-23-2013, 08:09 AM
Rotary Powered Countryboy
04RX8man's Avatar
Looks great!
Old 03-23-2013, 08:19 AM
Whozz xUr Dady7
Darkness8's Avatar
Old 03-23-2013, 09:09 AM
Reginald P. Billingsly
bose's Avatar
**** yeah! That looks *******. Good work.
Old 03-23-2013, 09:39 AM
olddragger's Avatar
please tell me he is not running this thing with the stock size rear tires--and WHAT STEERING SETUP did you use?
You will soon have a market for this conversion kit---i bet.
Old 03-23-2013, 09:41 AM
Mr_Pieper's Avatar
They used the Hinson kit. Apparently one made it out AND fit.
