automatic transmission filter location?
Old 11-23-2012, 05:22 PM
victor13b's Avatar
i need to know the location and removal instrucctions for the transmission filter!
location of the transmission filter in a 4 speed shiftronic rx8. It makes a squeaking noise so I think the filter is bad, does anyone know where it is?
year 2004!
Old 11-23-2012, 05:53 PM
There is not one IIRC.
http://foxed.ca/rx7manual/2003mazdar..._S01_0561.html
Old 11-23-2012, 05:57 PM
victor13b's Avatar
Originally Posted by 9krpmrx8
i see that post but i dindnt see the filter
Old 11-23-2012, 08:03 PM
Old 11-23-2012, 09:59 PM
what part of there is none that u dont understand
*facepalm x 2*
Old 11-23-2012, 10:04 PM
victor13b's Avatar
*facepalm x 2*
ok! no have filter inside the transmission! jmmm! sunday i will put down! for check the converter! '
thanks!
Old 11-23-2012, 10:27 PM
Hector Castillo's Avatar
que tipo de sonido hace? como si trajeras piedras devajo o en la trasmicion? aumenta el sonido en altas revoluciones?
Old 11-23-2012, 10:35 PM
victor13b's Avatar
.el carro lo compre hace 3 días . lo Prendes agarra los cambios bien pero como a los 4 minutos como q chilla cuando aceleras como si fuera un zumbido. u luego no agarra los cambios. pregunte lo del filtro pues pensé q lo tendría tapado. pero por lo q veo no lleva filtro dentro de la transmisión. pues sera el convertidor creo
Old 11-23-2012, 10:59 PM
que parte de texas estas?
Old 06-19-2020, 11:02 PM
No respecter of malarkey
Received 2,007 Likes on 1,636 Posts
yes there is one; called an “oil strainer” and mounts to the bottom / pan side of the control valve body
19-815
Mazda Part No. BW60-21-500
OIL STRAINER
$93.00 MSRP
Old 06-28-2020, 02:30 PM
vvette's Avatar
19-815
OIL STRAINER
$93.00 MSRP
Hey that's my car! Copy right 2020. LOL..Yes there is a filter!
nickrxeight
04-10-2011 12:06 PM
delhi
04-27-2007 08:02 AM
terretsboy
03-01-2006 12:52 PM
flatso
MedCenterMazda
03-03-2004 06:12 PM
Quick Reply: automatic transmission filter location?
