Car will not even turnover. Need Help Please!!
Old 10-18-2012, 12:00 PM
ngtumlin's Avatar
Just to give a quick rundown. HAd new motor put in about 6 months ago, due to not passing compresion. Car has been running fine ever since. Yesterday get in car and turn the key over, all dash lights come on radio play but nothing, car will not even turnover. you can turn key back and try again and repeat about 4 or 5 times and then miraculously it just fires right up. No lag in starter no hesitation nothing. Any ideas what might be going on?
Any help would be greatly appreciated.
Old 10-18-2012, 12:16 PM
Mr. Örange
TANKERG's Avatar
If you have a manual transmission it could be the switch on the clutch that lets it know that is been pressed all the way to the floor before it will engage the ignition. If you have an automatic transmission it could be that the linkage is loose and you're not all the way in park. You can try wiggling around the stick to see if it will start or try to start it in neutral.
Old 10-18-2012, 12:52 PM
T4XJS's Avatar
cool... something else i have learned, did'nt know they had a switch to confirm clutch pressed for ignition start up..
any joys ngtumlin..?
Old 10-18-2012, 01:15 PM
Mr. Örange
TANKERG's Avatar
It prevents you from starting the car in gear and running someone over.
Old 10-18-2012, 02:31 PM
Is your immobilizer light flashing?
I have had mine "loose" a key for some reason.......
Skyl3r
12-02-2019 04:51 PM
Shnifty
23
12-18-2015 12:49 PM
Peanutbuttertruffle
07-24-2015 07:49 AM
Bamaham
07-23-2015 08:08 AM
AussieGray
07-16-2015 03:58 AM
Rate This Thread
Quick Reply: Car will not even turnover. Need Help Please!!
