My RX8 will not turn over...
Old 07-21-2012, 02:28 PM
magallcg's Avatar
Unhappy My RX8 will not turn over...
Hello Everybody,
This is my very first post...I just recently purchased a used 2004 RX8 with 83K miles. Car is awesome, I just love the way it drives and it's killing me just watching it in the driveway not being able to drive. Anyway, yesterday I changed the oil on it, as I finished I turned the car on and was just letting it idle...I noticed the engine was a little bit more dirty than I like it to be so I tried to wash some of the dirt off with my water house. As I was putting the hose away, the car stalled...I tried to start it but nothing. I attempted it a couple more times (conscious of the flooding issue) and then it seemed like it wanted to start but it didn't. I decided to just leave it over night and not touch it..this morning I tried to start it and it turned over the first two times I tried, but now when I crank the ignition only the dash lights turn on and the car doesn't turn over. Can anybody suggest anything please. I even went as far as changing the spark plugs on it. I have also tried the flooding procedures, but even if it was flooded the engine should still turn, right? Help pleasee...
Old 07-21-2012, 02:32 PM
Sounds like the battery may be down....and you got something wet...
Likely flooded now
Recharge battery, let it dry off....check fuses...and do the deflood procedure or pull start it
Old 07-21-2012, 02:57 PM
I HATE SPEEDBUMPS!
monchie's Avatar
You may have wet some electrical components when your cleaning it, and now it's not starting.
Old 07-21-2012, 04:23 PM
magallcg's Avatar
I think it is something electrical...I really don't think it's flooded, bcus if it was flooded it would at least turn over, right? It just doesnt do anything...I turn the key to on for 5 seconds..then try to crank but it just doesn't do anything...I guess it's off to the dealer on Monday...gosh, I'm not going to sleep all weekend wondering how much that's going to be...
Old 07-21-2012, 04:27 PM
magallcg's Avatar
Likely flooded now
I was jumping it with another car when I was trying to start it this morning...wouldn't the car turn over if it was flooded? It just doesn't do anything, only the dash lights come on..
Old 07-21-2012, 04:33 PM
#225 of 1000
EricB's Avatar
not the brightest idea to go guns (hose) a blazin' in the engine bay.
Josh Hacker1985 (03-11-2020)
Old 02-02-2013, 08:36 AM
rotarystu's Avatar
i have a similar problem i have an 05 rx8 its drives fine but the other night i was backing into the drive way (tight squeeze) and i stalled it and tried to start it again a few times and it wouldnt start im guessing must likely flooded its happened once before and i fixed it but this time i connected the jump leads and tried to start it and nothing it wasnt cranking just one click when i turn the key i know its a vague description but im just wondering of any recommendations to my next step to fix this. it had no hot start issues but starter coils pulgs leads and battery are all original from 05.
Old 02-02-2013, 11:03 AM
Rockie Mountain Newbie
Bladecutter's Avatar
Originally Posted by rotarystu
starter coils plugs leads and battery are all original from 05.
You might want to change those.
Also, remove the spark plugs, remove the fuel pump fuse, crank engine until no more crap gets spit out of the spark plug holes. Install new ignition components, and start engine.
BC.
Old 02-02-2013, 11:24 AM
Sounds like a battery, power, fuse issue if it isn't turning over. Likely need a new battery
Old 07-17-2015, 03:44 PM
Rotary_revelution's Avatar
Corrosion on battery
Try cleaning the battey corrosion look for corroded wires, sounds like when your try and start it the ignition just clicks once and not turning over. Sometimes the battery wires need replacing if corrosion has moved up the wire
Old 07-17-2015, 07:28 PM
You gonna eat that?
BigCajun's Avatar
Received 2,600 Likes on 2,115 Posts
That was 3 years ago Bud.
Might want to check the post dates.
Old 04-16-2016, 09:06 AM
Travieso's Avatar
Hi i hve a 2004 manual mazda rx8,jus about a day ago i was driving and i notice that while in third gear i lost compression so i shift to second gear and then back to third gear and i regained compression and speed,i parked the car and it jus wont start,so i attached a jumper lead n jump start the car and it started but would only drive at a speed of 50,when i drive slower the engine cuts off,when i open up my banet i and checked properly one of my sparks plug leads were off,so i put it on and try starting n it still would start
Can some please help me here,i really love this car
F51
08-02-2021 04:07 AM
Nisaja
08-06-2015 01:27 AM
digitalmonkey79
07-29-2015 12:09 AM
RX7.9
07-20-2015 12:01 PM
ironj221
07-16-2015 10:16 PM
Quick Reply: My RX8 will not turn over...
