View Poll Results: Oil type
5W 10
33.33%
10W 40
33.33%
Synthetic W/anything
16.67%
75W90
16.67%
Something else?
0%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
What type of oil to use in the rx8?
I'm just curious about this subject especially because of the synthetic vs regular oil, 5W 20 vs 10W 40 arguments that I've read about. I just purchased a 2004 Lightning Yellow rx8 6 speed with 72,000 miles (for 9,500....) and the owner said that the dealership has been putting synthetic oil in it whenever they had the car serviced. I need some valid information because this is going to be my college car and I cannot constantly be stranded in the middle of nowhere. BTW I just registered with this forum and I DO know about the maintenence practices. And if this thread belongs in a different place then forgive me. So. What kind of oil is the right type to use? And is Lucas Oil Stabilizer a good idea? I know the manual says 5W 20 but I want to hear what you guys think
** READ THIS. It helps ALOT https://www.rx8club.com/new-member-forum-197/new-potential-owners-start-here-202454/ in fact, it is a sticky in this section, you should have already looked through it.
A friend at Mazda told me that 5W20 was selected to help improve the fuel economy by a tiny amount, and that 10W30 is best for the engine. Also that the 2009 and later engines especially should have no problems with synthetic or need to use special low-ash oil. I am personally planning to go with Redline 5W30 for my 2010 because it is very similar to their 10W30 and it's what I am already using in our other two cars. I would probably go with a 10W30 non-synthetic if I had a pre-2009 RX-8.
there has been alot of discussions on this, but have we ever had an actual poll?
i'm in the 5w20 boat (still debating the switch), but i also change my oil ever 3000km or 3 months, and top up with Royal purple 5w20/5w30/5w40, whatever is in stock at the local partsource.
And ya, premix is big, i do 5-6oz of Idemitsu, i use the Lucas 5.75oz containers (cleaned out first of course, i put the Lucas in my wife's Mazda 3).
on
'What oil to use' is the basis of holy wars since the birth of the rotary. It will not be answered by a simple poll. There is no consensus to find because one has never been reached. There have been polls, surveys, etc... and none of them form a conclusion because everyone has different environments, different beliefs, different goals, etc.
Read up on the pros and cons (usually made in the heat of e-battles) and make your own decision.
I am locking the thread because they usually degrade into flame wars.
you havent told us anything pertinent to give you any advice about oil. lets start with where home is and where the school is
edit- oh ahah its locked. well op determining what oil to use consider WHERE the car will be used and for what. then adjust the weight and change frequency to accommodate those conditions
Sifu
08-30-2015 10:51 PM
Jazzmeson
08-30-2015 02:23 AM
Jazzmeson
08-02-2015 09:49 PM
