RX8 Electrical Problems
Old 05-04-2012, 10:50 AM
simkolev's Avatar
Hi everyone,
Big problems these last 2 days with the RX8. Here's what happened:
Car was running perfectly fine, everything was ok. Then one day I got in the car, and the CD player just randomly started skipping a brand new CD. So I tapped on the faceplate a bit, and the skipping went away. Later it came back, so I tapped on it again, but this time it needed a bit of force to stop ( I know - I'm an idiot ) anyways after the last hit (which was harder) the entire thing just stopped working!!
So CD Player + Radio stopped working (won't turn on).. The center console screen (that displays temperature, time etc.) stopped working as well.
On putting the key in "ON" position, the speedometer & cluster pointers just spin left and right and then they go back to normal.
Key fob remote (unlock, lock, trunk opening) as well as the central locking do NOT work either. They worked PERFECTLY fine before this radio accident.
ALL of this happened instantly after the radio stopped working.
I disconnected the battery, then re-connected & tried to reset the ECM by pushing the brake pedal. Even did the odometer "TEST" thing.
What is going on? Any ideas?
Thank you in advance!
Old 05-05-2012, 05:24 AM
Grasshopper
Jon316G's Avatar
Check the 15A ROOM fuse in the kick panel.
Old 05-05-2012, 10:53 AM
simkolev's Avatar
Checked it and all other fuses too, they are fine.
Old 05-05-2012, 12:56 PM
Javii's Avatar
Any aftermarket parts installed? Has the battery been relocated to the rear? My radio will sometimes die when going over speedbumps because my battery is in the trunk
Old 05-05-2012, 01:01 PM
simkolev's Avatar
Nope, no aftermarket stuff.
It seems it's an issue with the computer. Alarm/locking key fob stopped working but the car also re-sets the computer every time i put the key in.
For example: I put the key in and turn to "ON" - the arrows in the instrument cluster go crazy for a second and go back to normal with lots of noises clicking under the hood for each component of the car. I put the key back to OFF -> ON again, no craziness/noises. But if I take the key out completely, put it back in and "ON" the arrows spin every time and the clicking starts.
How do I reset the alarm/locking?
Old 01-22-2013, 08:10 PM
Rx8KiiD's Avatar
Were you able to fix it? I have the same problem
Old 01-23-2013, 05:52 AM
simkolev's Avatar
Spent weeks looking for the shortage. Soon my A/C controls gave out and the car started flickering. I just went ahead and bought a whole new faceplate + A/C controls and problem solved.
A guy on RX8Club is selling one. PM "sanyok" he's got a faceplate from an 07.
Old 03-09-2017, 08:27 PM
Jon Drew Ousley's Avatar
Were you ever able to fix the problem. Your the only one I have found that had the same problem I have now.
ladnarf1
04-29-2021 11:53 PM
Skyl3r
12-02-2019 04:51 PM
SIllver
08-01-2015 07:34 PM
Belalnabi
07-22-2015 04:50 PM
Belalnabi
07-17-2015 07:48 PM
Quick Reply: RX8 Electrical Problems
