Front Driver Side Bose Speaker Plays Only For A Bit
Old 04-17-2012, 09:24 PM
jcrewlee's Avatar
My driver side speaker works sometimes and sometimes it doesn't work. I found out that if i hit the speaker cover on the door, it will turn back on for a few seconds. Also the rear speaker on the left side (same as driver side) is somehow connected to the front speaker because if i turn the fade all the way to the front/left, the left rear speaker is still playing. Any solutions before i start tearing apart the dash? OH BTW its a 2004 Bose System.
Old 04-18-2012, 04:01 AM
Super Moderator
ASH8's Avatar
Moved, Wrong Forum for 2004's..
I would be looking at connections which means removing door trim.
Old 04-18-2012, 04:13 AM
Central Valley RX8
Wind Dance's Avatar
Bose relay, look into it. Cost less than $3 tp fix
vapor2
10-08-2015 02:08 PM
akagc
08-11-2015 07:07 PM
MarkX
07-31-2015 07:50 AM
Majictoast
07-18-2015 06:45 PM
reverse01134
07-16-2015 10:27 PM
Quick Reply: Front Driver Side Bose Speaker Plays Only For A Bit
