Broke starter solenoid positive post
Old 03-06-2012, 09:48 PM
lmarcucci7's Avatar
I had a bit of a brain fart and didn't realize that the solenoid bolts were copper. I assume they were just copper plated. So, I was tightening the bolt and it broke off. How do I replace the bolt that is threaded into the solenoid and replace it with a new one? I guess I will just put my old solenoid on the newer starter for now.
By the way, I was doing the N3H1 to N3Z1 "swap" (I guess).
Also, I took the old solenoid off the old starter and I have no idea how I would go about getting inside of it. It seems like the plastic is glued to the metal. Also, I am pretty certain the "posts" are bolts because on one terminal it is loose and it feels like the head is rectangular and is trying to turn inside of another rectangle(The sides hit). (Sorry, for my extremely poor explaining skills)
Old 03-07-2012, 11:33 AM
2005 White GT
EDZRIDE's Avatar
Doubt you can replace just the bolt; a new solenoid is what you need.
Old 03-07-2012, 10:33 PM
lmarcucci7's Avatar
I think I will just solder the wire to the starter..
Old 04-11-2017, 09:15 PM
Marcos.rotary's Avatar
Broken starter solenoid
What did you end up doing? I just had the same problem.. As soon as I got the starter I installed it and the copper broke. Please help.
michael Dombrowski
Good Guy/Bad Guy
07-19-2015 05:19 PM
Quick Reply: Broke starter solenoid positive post
