Key fob programming
Old 12-21-2011, 10:27 AM
Dk663's Avatar
UK Key fob programming
Does anybody know how to programme a standard Mazda key fob to another rx8 can this be done locked my key in boot
Old 12-22-2011, 12:04 PM
Cohort's Avatar
uhh if someone did they arent going to tell you as it could very easily be used for illegal purposes
Old 12-22-2011, 01:02 PM
StealthTL's Avatar
The programming procedure lets you 'add' keys to the register, IF you present TWO already programmed/registered keys.
So no....
Old 12-22-2011, 11:37 PM
I HATE SPEEDBUMPS!
monchie's Avatar
That's what i thought. I don't think you could re-programmed a key fob to another rx8 with the same key on another rx8.
Old 12-23-2011, 08:28 PM
Charles Bundy
Grace_Excel's Avatar
You can reprogram(the keyless FOB and the micro-chip) an already functioning key from one RX-8 to another. I added a used switch blade bought in eBay with my existing set(two original and a lost valet keys) without any hitch.
If you want another key, two are needed and the additional key's blade have to be copied. With only one key, in your case, the new one have to be obtained from the dealer according to the VIN of your car. There's a thread about programming a switch blade for an '04 RX-8.
However, there's a limit to how many keys can be added before the ECU deletes all saved/programmed keys. The FOB on the other, I believe, does not and could be added multiple times. Both my original 2004 FOB stopped working even after I've replaced the battery which is the reason I'm using the switch blade from a 2006 RX-8. The procedure I used to adding a FOB only works with the switch blade, it will not work with the 2004 RX-8 FOBs.
Old 12-23-2011, 09:18 PM
Stars25's Avatar
If I remember correctly, you need to press the door button when programming a new FOB so you would need to have your car unlocked already in order to program a new FOB.
Old 09-19-2013, 01:54 PM
SilverBulletZ's Avatar
I hate to resurrect the dead, but I am a new RX8 owner, and when I bought the car, only 1 key came with it, and it is a generic brand.
It's supposed to have the "switchblade" key/fob, but I'm okay with it only having a "normal" key as the dealership calls it.
My question is this. If I get a key from somewhere other than the dealership in order to save some $$, will they still be able to program the key? I only have one, so I can't do it myself.
Old 09-19-2013, 02:51 PM
The key can be programmed easily by the dealer...so you are good to go
Old 09-20-2013, 02:56 PM
Nice, thanks!
Old 09-20-2013, 09:15 PM
if u're in NYC area(or close to it), I can program it for you for a "cheaper than dealership fee"
it's not hard, takes maybe 10 minutes.
Old 11-24-2017, 03:28 AM
William Ranieri's Avatar
How to reprogram a used switchblade?
Hi All new owner of a rx8 231ps 2003
Does anyone knows how to reprogram a used switchblade?
My car came with one "normal" key only! ....
thanks !@
Old 11-24-2017, 07:35 AM
Loki's Avatar
Search YouTube for "program rx8 key", there's a whole page of walk-throughs.
Eraser
08-11-2023 11:31 AM
galognu
Rotary Swaps
138
11-16-2020 05:20 AM
02-10-2020 10:23 PM
cliffkemp
10-03-2015 11:11 PM
09-30-2015 01:53 PM
Quick Reply: Key fob programming
