Car Stalling and Choking
Old 10-30-2011, 09:22 PM
Rotary Fanatic
kondypl's Avatar
I got Simota CF Intake couple months ago. I had some problems with it and I didnt know where the problem was. My car was stalling each time i put it on neutral gear and was slowing down to stop. Not long ago I finally found out bout removing vdaf :/. I know I was waiting too long because I was driving like that for couple months but I learned how to drive not to stall a car. Couple days ago something else started to happening. My car was stalling each time , my technique to take it off gear last second stopped working , car was going off almost every time i was stopping at stop or red light. It also started rattling/choking when driving on 5th/6th gear on lower/normal speeds (40/45mph). I also got CELL on one time when it started choking. Until I got to Autozone day later the check engine went off so I dont know what code it was. Yesterday I took the vdaf off hoping its gonna fix the issue but it didnt. Car still stalls and chokes but CEL is not coming back now. Do you think my MAF sensor gave up because I was driving like that for couple months? or what might be an issue?
Old 10-30-2011, 10:16 PM
BECAUSE RACECAR
Arca_ex's Avatar
First did you search? The obvious answer is no.
Did you reset the fuel trims by doing a 20 brake stomp?
Did you go back to stock to see if it's just your intake?
Did you read the directions carefully and make sure it was installed properly?
Old 10-31-2011, 12:51 AM
Rotary Fanatic
kondypl's Avatar
I did unplug the battery but no I didnt that 20 braking? What is it for? Yes everything is installed properly , didnt try to go to stock yet but I might soon to check.
Old 10-31-2011, 12:56 AM
BECAUSE RACECAR
Arca_ex's Avatar
http://lmgtfy.com/?q=site%3Arx8club.com+ecu+reset
Old 10-31-2011, 03:57 PM
Sisco360's Avatar
Clean your throttle body and MAF sensor. I had the same problem for ages. Cleaned the throttle body last week and the thing runs brand new.
Old 10-31-2011, 04:00 PM
You need to systematically check everything and reverse anything you have done. Stalling can be something very simple or it could be a loss of compression. Either way the issue has been discussed a million times so there is no need for this thread. Once you have read those other threads and tried the most common stuff then it would be appropriate to start a thread on the issues you are having.
Skyl3r
12-02-2019 04:51 PM
RayBarron
10-19-2015 08:08 PM
Quato_jr
08-04-2015 09:22 AM
Peanutbuttertruffle
07-24-2015 07:49 AM
Bamaham
07-23-2015 08:08 AM
Quick Reply: Car Stalling and Choking
