Compression test results after Repair Procedure A+B from service bulletin 01-015/08
Old 07-03-2011, 03:55 PM
05 6MT RX8
jreide22's Avatar
VA Compression test results after Repair Procedure A+B from service bulletin 01-015/08
Hey everyone, I just bought a 2005 Sunlight Silver 8, 6spd with 62,500 miles on it from a trusted dealer here in VA. I asked the service tech for any records and he gave me a few printed out pages.
I noticed on one page it said that in March of 2009 (engine had 31,000 miles) the previous owner issued the "Engine cranks but will not start" complaint and Mazda performed Repair Procedure A+B From Service bulletin 01-015/08. The engine compression test results were as follows:
Front Rotor: 791.08, 782.08, 766.08
Rear Rotor: 747.42, 735.42, 719.42
After reading through the service bulletin I believe they used the engine cleaner process as well to clean out any carbon. They also replaced the wires, coils, etc, replaced the air filter and replaced the catalytic converter at this time.
My question is, are these numbers where they should be? I know nothing about compression test numbers or how to interpret them even after reading through some other threads on this site (being new to this site I must say there is SO much information and it has been extremely helpful in answering most of my questions).
Also, since this was done about 2 years ago should the compression results be about the same? The oil was just changed about 700 miles ago and I was going to use a seafoam or techron treatment in the tank before my next oil change.
The main reason I wanted to know about the compression test results and use the fuel system treatment is because I wanted to try and get an increase in gas mileage (although I know it wouldn't be much). Can anyone help me out?
Also, if I read through the service bulletins and notice a problem that I am having that matches one of the bulletins, can I simply take the car into the mazda dealership and ask them to fix it under warranty? Thanks
Old 07-03-2011, 05:23 PM
2005 White GT
EDZRIDE's Avatar
Nope
Old 07-03-2011, 09:22 PM
Old Rotor's Avatar
Looks like a good time to do a tune up.....at least spark plugs....
Old 07-03-2011, 10:05 PM
weeeeeeeeee
ShellDude's Avatar
The service bulletins tend only be "free" when you have a bumper to bumper warranty. About the only thing covered after that is the cat, and engine core.
Some of the nicer dealers will do the work for free though, but don't hold your breath. All the others will happily charge you too.
Old 07-04-2011, 02:40 AM
I HATE SPEEDBUMPS!
monchie's Avatar
Did the dealership who performed the compression test ever told you if it passed or not? Just curious.
Old 07-04-2011, 08:53 AM
Hermitage Holdout
VOODOO8's Avatar
Need to know what RPMs the engine was cranking at to properly correlate these numbers against the standard chart for good/bad readings.
Attached Thumbnails Compression test results after Repair Procedure A+B from service bulletin 01-015/08-rx8-compression-pressure-chart.jpg
Old 07-04-2011, 10:48 AM
05 6MT RX8
jreide22's Avatar
Well the dealership that performed the test was in another part of VA and did it for the last owner, so I don't know if it "passed" under their terms.
I also don't know what rpm the engine was cranking at, I just assumed that they did it at 250 rpm but then again I probably shouldnt just assume that right? I just wanted to know if I should get another compression test even if I don't realize any loss in power or rough idling, etc. or if I should do a seafoam treatment just to get some smoother riding, better gas mileage, etc?
WranglerFan
05-31-2022 07:51 AM
gwailo
06-07-2020 12:21 PM
02-27-2020 08:39 AM
TJSiegrist
09-10-2015 09:29 AM
rxwilly8
09-02-2015 02:42 PM
Rate This Thread
Quick Reply: Compression test results after Repair Procedure A+B from service bulletin 01-015/08
