Hard to start when hot..
Old 02-18-2011, 03:30 PM
BReal-10EC's Avatar
I changed the plugs and coils in the last 10k miles. Though I did not change the wires- the car only (04 6sp rx8) has 40k miles now.
I Seafoamed last weekend, and thought that may have done the trick.
But nope- it is hard to start when hot again.
If it is good and hot and I just shut it off for a few minutes, it spins like it is flooded when I try and restart it (which is why I assumed it was a carbon/gunk compression issue before, and not the short plugs wires).
Sometimes I have to sit for a few minutes and let it cool down (maybe 5-15 minutes) and then it will start. Sometimes it will start after cranking it for a very long time (before battery dies/starter overheats).
Note I sort of over Seafaomed it (sucked entire can in one port, and then another can in the other port). But I don't see how that could hur the compression.
Ideas? Do I need a new engine at 40k miles? Or is there something else I should try? I really need a car that I can trust during my work hours. So now it's either- watch out for flooding, or watch out for it being good and warmed up. lol.
Old 02-18-2011, 03:36 PM
Dragon Certified
987HYS's Avatar
That is a common problem. there is an alternative sparkplug you can use that Mazda came out with to help with this problem. you can find one here... http://mazdatrix.com/8ignition.htm
Old Rotor's Avatar
Time for a compression test.
Old 02-18-2011, 04:04 PM
Time for boost...
RX8Soldier's Avatar
+1
I've heard of engines being replaced at 25k miles
Old 02-18-2011, 04:47 PM
BReal-10EC's Avatar
Yeah.. unfortunately the Mazda dealer in town closed last year (but may reopen at a different location).
And I really need to make sure the car is good an hot when they do the compression test.
Though it does make me wonder- how does the engine cooling down a bit give it better compression? Well, maybe the housing cools before the rotors and there is a micrometer less of apex clearance...
On the plus side- if I get a new engine, I guess that would be a good time to change the worn motor mounts...
Oh- and doh! I realize I put this in the wrong forum area (should have been trouble shooting forum).
my bad.
Old 02-18-2011, 04:48 PM
BReal-10EC's Avatar
..and is this site super slow for anybody esle? weird.
And I just remembered there was oil in the intake tube ribs.
I must have over filled the oil last time it was low...
So I guess I shoudl clean the MAF/IAT .. which probably would make it hard to start if they were not getting good readings.
Will do that tommorrow.
poppinparker
08-10-2015 09:20 AM
harithac
07-25-2015 04:21 PM
dbarber
07-25-2015 01:34 PM
dmac1961
07-24-2015 11:27 AM
Quick Reply: Hard to start when hot..
