Found Black RX8 Mazda Emblem
Old 10-23-2010, 07:22 PM
I drive at Red Line.
DocBeech's Avatar
I found a site that sells black mazda rx8 emblems. My plan is to use carbon fiber vinyl on a black emblem on the new hood.
http://www.rvinyl.com/carbonfibervinyl.htm This is the vinyl
http://www.streetunit.com/StreetUnit...p/surx8boe.htm is the badges.
fyi you could also use the carbon fiber vinyl to save yourself a lot of money and wrap the center console trim pieces instead of buying real carbon fiber trim pieces.
Old 12-19-2010, 05:55 PM
Needs Boost!
dmedz8's Avatar
yeah but does it look and feel like carbon fiber?
Old 12-19-2010, 08:21 PM
terch1's Avatar
Just remove them all together. Go badgeless ........ at least on the front.
Old 12-19-2010, 08:22 PM
terch1's Avatar
I don't know about applying an emblem to the hood....... although I guess it would be original being I've never seen it done.
Old 12-20-2010, 05:40 AM
DocBeech's Avatar
It depends on the carbon fiber that you buy, but what do you mean feels like carbon fiber? My hoods carbon fiber and it feels like glass since its UV coated heavily.
Old 12-20-2010, 06:09 AM
Twiztog43's Avatar
so wait a minute, your going to wrap the black emblem in cf vinyl on a hood?
or are you going to wrap the hood in cf vinyl and put the emblem on the hood?
both seem odd because i have never seen an emblem on the hood. but unless your debadged [on your front bumper] your going to have Mazda emblems in the front of your car?
also that site selling the black mazda emblems seems like a ripoff. just take off the existing mazda emblem [fishing line or dental floss with a heat gun or hair dryer.] and paint it yourself. its pretty simple if you take your time and do not rush things. that would probably cost you around 1o -15 bucks for primer/black paint and clear.
Old 12-20-2010, 06:17 AM
DocBeech's Avatar
I am getting a new front bumper, and I am also getting a CF trunk. I already have a CF hood. The new front bumper isn't mounted for badges, so more than likely what will happen now is the RX-8 emblem will be all that gets put back on. It will be black with CF overlay then mounted center on the rear of the car. I have been thinking about getting either a rotary emblem badge or some kind of just RX-8 for the front of the car. I posted this months ago before I destroyed the front bumper.
Old 12-20-2010, 06:32 AM
PHREN PHUN!!
phrenetiK's Avatar
if i were you when you add the badges id shave/cut off whatever they use to mount with and just applying 3m tape so if you want to debadge later it is easy and you dont have new holes.
Old 12-20-2010, 08:07 PM
Needs Boost!
dmedz8's Avatar
basically what im saying is will it feel like a sticker?
Old 12-20-2010, 08:32 PM
DocBeech's Avatar
you will have to order test samples and decide that for yourself. It does have to be applied with a hair dryer so its a little thicker than you think
Old 12-26-2010, 02:15 AM
Rigoherrera's Avatar
i actually ordered some of that 3m tape to sample it so i can wrap a few things in my car and yeah its a little thick, but its very flexible and it can stretch when u put enough heat on it, also it does have some texture to it, so it dosent feel like a sticker
SayDfuse
11-21-2015 02:35 PM
mariohardleft
09-13-2015 11:17 PM
akagc
08-11-2015 07:07 PM
MolecularConcept
08-05-2015 04:43 PM
AussieGray
07-16-2015 03:58 AM
Quick Reply: Found Black RX8 Mazda Emblem
