disable alarm???
Old 10-08-2010, 04:24 PM
chino0314's Avatar
disable alarm???
is there a way to disable the stock theft system??
Old 10-08-2010, 04:33 PM
Received 2,625 Likes on 1,875 Posts
stop trying to steal RX-8's.
True love is blue x2
xun4gvn4everx's Avatar
Jorge is onto us...
Old 10-08-2010, 04:34 PM
chino0314's Avatar
lol im trying to start mine :/ and the little light on the dash with the car witha key in it keep flashing....
do the rx8s have some sort of kill switch ?
Old 10-08-2010, 04:35 PM
what pattern is it flashing with?
sounds like an issue with the immobilizer; might be a blown fuse.
Old 10-08-2010, 04:36 PM
chino0314's Avatar
just constant flashing no pattern....
Old 10-08-2010, 04:37 PM
Yea, I would def suggest starting with the fuses. It's the cheapest and easiest fix, if in fact a fuse is the issue.
Old 10-08-2010, 04:38 PM
how many times is it flashing?
I'm asking because I was reading the service manual recently and based on the number of times it blinks and the pauses in between, you can help diagnose the issue.
have a copy of the service manual?
if not, let me know.
Old 10-08-2010, 04:39 PM
chino0314's Avatar
i do not have a copy :/
Old 10-08-2010, 04:42 PM
chino0314's Avatar
lmao legally purchased also its continuous flashing doesnt stop
allow me to consult my manual and I'll get back to you.
Old 10-08-2010, 04:43 PM
is the key icon flashing rapidly non-stop?
Grasshopper
Jon316G's Avatar
Bottom of first post for the Immobilizer System Inspection:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-diagnostic-outputs-155947/
chino0314's Avatar
yes
Old 10-08-2010, 04:46 PM
thanks Jon, that is what I was referring to.
I can unsubscribe from this thread now, Jon is here to assist.
Old 10-08-2010, 04:48 PM
Grasshopper
Jon316G's Avatar
What.... Hey... Don't leave me alone... Damn you... LOL
Jon always comes to the rescue!!
Old 10-08-2010, 04:49 PM
Old 10-08-2010, 04:54 PM
Grasshopper
Jon316G's Avatar
If its a continuous and consistent flash pattern, that might point to the immobilizer itself.
You could try to disconnect the battery for ~10min and reconnect, then see what happens.
Sometimes a good "reboot" helps.
If you have a 2nd key, give it a try too.
Even though it doesn't match the flash pattern, its something else quick and easy to rule out.
Old 10-08-2010, 05:03 PM
chino0314's Avatar
ok tried both keys and nothing
rebooted the car last night
continuous flashing for about a minute and then it flashes 20 times with a 4-5 second break between flashes.. then stops flashing completely
Old 10-08-2010, 05:07 PM
Grasshopper
Jon316G's Avatar
Curious... when was the last time you had the car started?
Old 10-08-2010, 05:09 PM
chino0314's Avatar
last week thursday
Old 10-08-2010, 05:12 PM
Grasshopper
Jon316G's Avatar
Might sound a little strange, but can you test the battery voltage?
Possible that the battery is drained and is only supplying enough to illuminate a few lights.
Old 10-08-2010, 05:13 PM
chino0314's Avatar
checked that already 12.30v
Old 10-08-2010, 05:25 PM
Grasshopper
Jon316G's Avatar
Damn... well, can't think of anything else besides the immobilizer components.
And with replacing those, you'll need the dealer to perform it anyway to register them to the keys.
Wish there was something else I could recommend trying...
Rate This Thread
Quick Reply: disable alarm???
