DAMMM!!! my car die for the on me !! please help rx8 brother
Old 10-03-2010, 07:39 PM
TQCuong3th's Avatar
NY DAMMM!!! my car die for the on me !! please help rx8 brother
so i was driving to the mall when i at the stop light i press on the brake tall the sudden my car die, engine shut off , try to start it again it crank battery it working but it dont seem to talking to the engine then ten minute later i try to push and start all the sudden it work again, got so happy got to the mall park then shop then go home,,, on the way home it die on me at the red lightnow i try to crank push then crank but it still dont start but it still cranking thought so i waited for 20 min for my friend father to come then he start the car and it work again so i drive it home and park please help ???? i have 2 year warranty any suggestion????
Old 10-03-2010, 08:07 PM
RIWWP's Avatar
1: engrish
2: take it in for someone to look at because i cant tell what might be wrong from that atrocious post, and i am not hopeful that pressing for details might get me anywhere.
Old 10-03-2010, 08:54 PM
I drive at Red Line.
DocBeech's Avatar
yeah, don't flood your engine.
Old 10-03-2010, 11:16 PM
TQCuong3th's Avatar
yea that wat i try not to do , it like if the engine want to turn on then it turn but it dont then it wont should i bring to the dealer to look at ? would that cost me money >? i have warranty on it
Old 10-03-2010, 11:22 PM
Power!!
shaunv74's Avatar
It's not flooded. Have you ever changed the ignition coils plugs and wires? If not you should swap them out first. You can get the parts on www.finishlineperformance.com. If it doesn't improve:
Take it to the dealer and tell them what happened. This is a common symptom of bad ignition coils and plugs or a dying motor. you have an 8yr/100K factory warranty on your motor so if your motor is bad it should be replaced under warranty. They'll probably want to swap out your coils plugs and wires first so I suggest you do it yourself first and save some money.
F51
08-02-2021 04:07 AM
Skyl3r
12-02-2019 04:51 PM
marc2820
07-26-2015 10:47 PM
T_Mags
07-24-2015 11:29 AM
Bamaham
07-23-2015 08:08 AM
Quick Reply: DAMMM!!! my car die for the on me !! please help rx8 brother
