P0661 help
Old 09-29-2010, 10:33 PM
chabinator's Avatar
P0661 help
Hi, my 2004 mazda rx8 100k miles has a p0661 code.
I swapped the ''ssv solenoid valve'' with the ''air solenoid valve'' to see if the code would dissapear. The code stayed there.
So, it's probably not a solenoid malfunction.
What else could it be?
The dealer found there was no vacuum on the ssv actuator..
HOw do I repair this????
thank you
Old 10-10-2010, 10:27 AM
Eccentric Shaft
Calmstorm's Avatar
This is a strange question. The dealer found no vacuum on the ssv actuator, but had no idea how to proceed from there?
Old 10-10-2010, 05:54 PM
Grasshopper
Jon316G's Avatar
The dealer didn't offer any assistance with this?
If the dealer applied vacuum directly to the actuator and it's not holding vacuum, then the actuator needs replaced.
Only way for you to be certain is to test the actuator yourself with a vacuum pump.
Should hold ~10in.Mg for several seconds without rapidly bleeding.
Old 10-11-2010, 01:31 PM
chabinator's Avatar
it was the solenoid finally......
thanks all
cushing75
11-12-2018 12:46 PM
MANIACman
11-11-2015 10:58 PM
Rx808BI
08-09-2015 10:06 AM
ShinkaEvo
01-27-2014 01:20 PM
ken-x8
05-27-2013 11:00 PM
Quick Reply: P0661 help
