HOW DO YOU REMOVE THE BATTERY FROM THE 2006 RX8 kEYLESS rEMOTE?
Old 09-25-2010, 04:47 PM
themodcity's Avatar
i'M GOING CRAZY TRYING TO FIGURE IT OUT !!!
Old 09-25-2010, 04:52 PM
SARX
cornholio135's Avatar
1.Remove Emergency Key from remote
2.Above the "Bump" that secures the key use your finger to pry up the rubber piece exposing battery
3.Tap on table till the battery falls out
Done...
Old 09-25-2010, 05:25 PM
Jacob6875's Avatar
It says how to in the manual for the car just follow it....
Old 09-27-2010, 12:21 AM
Zoom x 2
XlYesterdaYlX's Avatar
Use a paper clip and your imagination.
Old 09-27-2010, 06:32 PM
themodcity's Avatar
piece
tried that, the little plastic piece broke off......
Old 09-27-2010, 06:41 PM
Don't forget love and care will reward you with success.
Old 09-27-2010, 06:54 PM
jasonrxeight's Avatar
how hard can that be?
take out the key, use a small screw driver open the gate its made from rubber
Old 09-27-2010, 08:12 PM
Zoom x 2
What?? Since I have nothing better to do, I'll spell it out for you....by chance this is not the key you have. Iono wtf to tell you.
Old 02-21-2011, 07:44 PM
Litespeed&RX8's Avatar
Very Helpful, I just replaced mine - using 'The Paper Clip Wiggle' method
One Hole on the 2008 .
2008 Anniversary Edition - Racing Beat REVI/Combo - Nitto INVO - CorkSport Exhaust
AMSOIL - Idemtisu
Old 07-13-2011, 02:49 PM
tibyABv6's Avatar
Any one know if i have to reprogram remote after replacing battery?
Old 11-23-2012, 03:57 PM
Frank Clark's Avatar
Smile Tiny depression style slots hard to see
I sympathize with your frustration. I too had a very hard time finding the special "slots" to press with the mini-screwdriver. Once I found them, the top cover was very easy to remove.
Look closely at the very end of the key fob, after the switchkey part has been removed. You will see two tiny rectangles, about the size of the tip of your mini-screwdriver, and not deep at all.
At first these slots look unrelated to the top of the keyfob. It is these tiny slots that need to have the screwdriver inserted, and then twisted. The cover will then come off easily. A mini-screwdriver blade is needed, not just a small screwdriver.
Do not try twisting the larger holes. Your keyfob will break. Good luck!~
Old 11-24-2012, 07:17 AM
40w8's Avatar
When you figure it out you're gonna feel real dumb it's so easy kind of thing.
The batt # is easy to find at last minute cheap, and seems to run out about every 2 years.
The book says to just replace once a year, so they already know the deplete rate.
Old 11-26-2012, 02:49 PM
milkis's Avatar
my finger nail to get the plastic unhooked, then a card(bank or credit) to get battery out.
Old 11-26-2012, 03:07 PM
HiFlite999's Avatar
Oh that's far too much work.
rotorocks
47
05-11-2016 03:23 PM
Zank300
08-26-2015 07:40 PM
xandersonx97
08-02-2015 01:02 AM
robd1337
07-31-2015 09:35 PM
BamaRules777
07-25-2015 08:45 PM
Quick Reply: HOW DO YOU REMOVE THE BATTERY FROM THE 2006 RX8 kEYLESS rEMOTE?
