obd2 scanner
Old 09-17-2010, 05:03 PM
pctsean's Avatar
VA obd2 scanner
anybody buy any mazda scanners that work well with the 8? any input?
Old 09-17-2010, 05:11 PM
Trained true Killers
the1jesster's Avatar
I bought mine of ebay for 40 bucks works fine
Old 09-17-2010, 05:24 PM
The devil made me do it
DeViLbOi's Avatar
Any scanner will work with the 8...the key is to bring the code here so you can get the rotary version of the code because it really sucks to try and diagnose a cam problem on the 8.
Old 09-17-2010, 05:27 PM
Grasshopper
Jon316G's Avatar
Originally Posted by DeViLbOi
Any scanner that supports CAN-bus protocol will work with the 8
Fixed
Old 09-17-2010, 05:30 PM
Asshole for hire
paulmasoner's Avatar
most of the P and U series of codes are universal to all vehicles using the modern regulated CANbus systems.
example P2109 - Throttle Postion Sensor minimum stop range/performance problem is the same on any vehicle, only minor details if any will be different from vehicle to vehicle. Its an industry standard.
Old 09-17-2010, 05:41 PM
DeViLbOi's Avatar
Are there really that many that don't support CAN?
Old 09-17-2010, 05:42 PM
Grasshopper
Jon316G's Avatar
Nowadays... no.
But people might have older scanners or some might be selling their used units online.
If buying new, wouldn't worry about it.
Buying used... I would verify.
03-14-2021 03:53 PM
02-27-2020 08:39 AM
02-10-2020 10:23 PM
fistofmeat
10-07-2016 12:15 PM
iwannarun
09-06-2015 01:37 PM
Quick Reply: obd2 scanner
