Glowing cat
走り屋
on
Glowing cat
My car is beginning to smell pretty bad after romping so I looked underneath last night after a "spirited" drive and I noticed the cat glowing through the heat shield. I've already read up on the cause, warranty replacement etc but I was just wondering if it would be worth it to get a higher flowing cat. I know that they are mostly universal which kind of sketches me out. Would it be worth it or should I just see if they will replace it under warranty?
Cheers
Cheers
I divide by zero
on
If its under warranty and you are fine with the stock cat, go get the free one. If you want somethign that flows a little better, buy a decent high flow cat. Honestly I'd go get the free new one either way, then you have a new one in the garage incase you want to go back to stock later.
