P0302 cel need help
on
P0302 cel need help
Yesterday while driving around town, the engine started wanting to die at idle and running really rough. started getting flashing cel, so i pulled over and noticed some white smoke coming from the back of the engine compartment(engine temp was normal). also noticed that the cat was extremely hot with very loud popping noises. so i had it towed back to the house and removed the cat figuring that it may have been clogged. But i am still getting cel codes P0302(rotor 2 misfires) and P0171(system running too lean). Should i replace the plugs next? any help is appreciated
ps: 04 6mt stock with 48000mi
on
to be honest i am not sure when the last time they have been changed. i bought it used about a year ago from a dealer and figure that they were changed before i purchased it but not 100%. i have only put 9 or 10k miles on it. does it sound like thats the problem?
mine did the same last week i replaced the plug and im waiting for my wires n coils to arrive the cel turn off but in the mornings when i start it it still have some rough idle but hopefully will go with the wires and coil........ if u do it yourself remember to reset the e-shaft
03-14-2021 03:53 PM
Evan Gray
09-26-2015 12:30 PM
1.3_LittersOfFurry
09-22-2015 01:54 AM
