Check engine light flashing
on
i was driving yesterday and everything was just fine, all of sudden i started loosing power and the check engine light started flashing, now its very hard to drive. i got it scaned at autozone and they said its missfiring in "cyclinder one" so it seems like its just sparkplugs are bad but im not an expert and want to make sure. also i was wondering should i also change my coils just in case? by the way the car is 2004 with 57,000.
drastic: are you on the original plugs, wires, and coils?
If so, listen to the Jon and OR as those are most likely the culprits
on
i believe im still on the same coils and sparkplugs since im the 2nd owner i dont really know for sure. but i already ordered the parts from rotoryfx. thanks alot for the feed back, i really appraciate it!!
I had the EXACT same problem yesterday, and like you took it to Autozone where they told me the EXACT same thing, Im sure for me its just the spark plugs or wires, I had the ignition coils all changed last month, Im with you buddy :/
correct, NGK's do not need to be gapped
on
I changed the spark plugs and she ran fine, I dove around for about 20 minutes. I let it sit there for about 3 hours then when I was ready to drive again when it started stutturing again n died.. I'm getting coils on monday cuz that's my second guess. It's odd because the engine light flashes n stay on, the car baraly starts. My friend told me to check the coils by keeping the engine on n unplugging each one at a time to see if the engine dies and determine if it's good??? Would it over flood? Lastly my friend said I should check the crank sensor? Sorry it's so long but I'm confused!!
akagc
08-11-2015 07:07 PM
