RX8 Engine Problems
Old 04-16-2010, 06:08 PM
GreatSaski's Avatar
RX8 Engine Problems
Ok, so I've been reading up on some of the problems the RX8 has been known to have. I bought an '04 a year ago with 24k miles on it. I've read that a lot of people have had to get their engines replaced around 30k miles. I was wondering if anyone here has had any problems and had to get their's replaced and if it's common or not. The reason why I've been reading up on it is because last October I had to get a new ignition coil and O2 sensor, and today I found out I need a cat. converter. Thanks.
Old 04-16-2010, 06:16 PM
alnielsen's Avatar
Location: Buddhist Monastery, High Himalaya Mtns. of Tibet
Keep your oil change receipts and you shouldn't have any problems with getting Mazda to replace it under the 8 yrs/100K mile warranty.
I've had 3 engines replaced in my car. I believe that 2 of the were caused by a bad (clogged) cat. I've had a few of those replaced too.
Old 04-16-2010, 06:24 PM
GreatSaski's Avatar
Oh ok, I wasn't aware of the Mazda warranty. So no matter what kind of warranty I have from the dealer, the Mazda warranty is what's important when it comes to engine replacement?
Old 04-16-2010, 06:28 PM
alnielsen's Avatar
I have attached a copy of the engine warranty document. If you bought a extended warranty for the car then your double covered. The Mazda warranty doesn't cover a rental car. Your extended warranty may.
File Type: pdf
Old 04-16-2010, 06:53 PM
GreatSaski's Avatar
Would this warranty apply to me even though I bought the car used from a dealer that wasn't Mazda? When I bought the car there was no mention of the warranty.
Old 04-16-2010, 07:00 PM
alnielsen's Avatar
Yes, it applies to all RX8's of the model years 2004-2008. 2009 they came out with a revised engine that had a couple of small changes.
vapor2
11-03-2020 03:38 PM
Skyl3r
12-02-2019 04:51 PM
Rx8Lovin
07-25-2015 08:39 PM
netrovers
07-20-2015 03:32 AM
Belalnabi
07-17-2015 07:48 PM
Quick Reply: RX8 Engine Problems
