Series II ECU Tuning
Old 12-01-2011, 05:33 PM
  #451
Moon Assad's Avatar
Ok, the powermod is a go but it took alot of BS to figure out what would work. I had to put 650cc injectors in the primary holes wich seems to have worked very well. It will work until theres some way to flash.
Old 12-07-2011, 03:22 PM
  #452
it kopek
Ogulcan's Avatar
We are trying make a harness for Haltech Sprint RE. If anyone has the ECU pinout diagram that will be really helpful asap we make it work I'll post it here
Old 12-07-2011, 06:59 PM
  #453
Super Moderator
ASH8's Avatar
Good Luck!
Old 12-07-2011, 11:42 PM
  #454
No respecter of malarkey
Received 2,007 Likes on 1,636 Posts
you can use any aftermarket PCM with a custom boomslang harness which is really NBG, controlling CELs etc. is another matter ...
Old 12-08-2011, 03:41 AM
  #455
it kopek
Ogulcan's Avatar
ASH8, Thank you so much for the documents those really will help so much!
Old 12-08-2011, 10:48 AM
  #456
Former Sponsor
RIP IT!'s Avatar
Find the connectors that fit the S2 ECU and I am in for making a Boomslang harness. I have not been able to find them.
Old 12-08-2011, 10:53 PM
  #457
a PCM and harness out of a wrecked S2 would do, but cutting the wires and tapping them directly is about the same thing other than it coming to you as PnP ...
Old 12-09-2011, 04:41 PM
  #458
it kopek
Ogulcan's Avatar
Got em already it needs hours and hours of hardwork :D Now working on harness hope I will have good news in next 2 weeks
Old 02-08-2012, 05:36 PM
  #459
RX8 Autocrosser
MobiusAce's Avatar
So... Any news? :
This is about as disheartening as the S2 supercharging thread..
Old 02-19-2012, 10:37 PM
  #460
bcdjudo7's Avatar
I am not Jeff, but a Haltech is an option. The problem is that I could not find anywhere to source the connectors for the ECU in order to make a patch harness. Because at this point your factory harness would have to be cut allowing the Haltech to be patched in, but you would have full control over ignition, timing and any other features you wanted to use. It really opens the platform up for more possibilities.
If someone really wants to try feel free to hit me up. Again the problem I am having is creating a patch harness. IF there is someone who wants or can figure out where to source connectors I am all in for helping you guys create a system to tune series 2 cars. I just have not had anyone who wants to cut the factory harness and void their warranty, and is why I have not further posted in this thread.
Only update i can give is that I'll be trying this prob late april / early may . Been talking with him by email here and there. My factory warrnaty is gone this summer anyway so I could careless about that at this point .... so worst case scenerio , we'll have an option hopefully after I get my car done with the Haltech .
Old 04-09-2012, 10:41 PM
  #461
bcdjudo7's Avatar
Ok .... looks like it will be first weekend of may that i'm bringing the car to him. He will have to a couple weeks for dyno runs and tuning using the haltech. Results to be posted afterward
Old 04-10-2012, 08:27 PM
  #462
RX8 Autocrosser
MobiusAce's Avatar
Can't wait to hear the good news!
Old 04-15-2012, 08:40 AM
  #463
olddragger's Avatar
I have a feeling ( not fact based) that this year will be a good year for you sII guys.
Old 04-23-2012, 12:40 AM
  #464
bcdjudo7's Avatar
God I hope so
Old 05-05-2012, 11:00 AM
  #465
bcdjudo7's Avatar
Ok .... dropped my car off to Brad in Oklahoma city to get haltech installed. He said figure 2 to 2 1/2 weeks or so. Really looking forward to seeing what this will do.
On another note, got to check out his shot. Pretty cool stuff he's got going on over there. Guy can do just about anything you would want with a rotary whether it be a 20 b or a turbo set up. Plan for me is once i get this thing tuned with the haltech, prob going to do a turbo set up next summer with him.
I will post results once i have them .
Old 05-06-2012, 06:53 PM
  #466
RX8 Autocrosser
MobiusAce's Avatar
Old 05-14-2012, 10:40 AM
  #467
jrx13's Avatar
Which Haltech are you getting installed? Platinum 1000 I assume? And I also guess you will be doing a "parallel" installation, meaning your retaining the stock PCM to control things like the instrument cluster and the drive by wire?
Old 05-16-2012, 05:01 PM
  #468
bcdjudo7's Avatar
Yes I believe it's the 1000 ... The unit has the capability to run the entire car, but yes .... will be keep the factory computer running instruments, steering wheel control, etc and then the haltech will basically just be running the engine.
Old 05-25-2012, 10:09 PM
  #469
Rotared
Rotary Inspired's Avatar
I can say as of today there is a solution for Series II tuning. bcdjudo7's car is up and running on the platinum sport 1000 without a check engine light on.
Brian,
Thank you for allowing me the opportunity to work on such a fine example of a RX8.
Brad
Old 05-25-2012, 10:45 PM
  #470
But is it making more power NA? Will this allow boost?
Old 05-25-2012, 10:55 PM
  #471
Rotared
Hasn't been on the dyno yet. Yes It can be boosted now. I have full control of the engine.
Old 05-25-2012, 11:12 PM
  #472
paimon.soror's Avatar
Brian,
Brad
More info!! Now that you have a working solution, can you estimate a final cost?
Old 05-26-2012, 12:10 AM
  #473
Rotared
More info next week after its on the dyno. I cannot advertise on here as I am no longer a sponsor/vendor so I cannot speak about price on here.
Old 05-26-2012, 12:21 AM
  #474
Will it run the DBW throttle
The APV valves?
Does it allow individual staging and control over the fuel injectors?
The MOP?
Old 05-26-2012, 08:17 AM
  #475
bcdjudo7's Avatar
Ahhhh he beat me to it ! lol .... all up and running guys. No final results yet , though as we haven't had it on the dyno and tuned which he is doing next week. We'll know then what it added power wise. I'm picking car up next weekend and we're going to talk about doing a turbo at some point.
To answer some of the questions, the unit has the capapbilitiy, from what i was told, to control everything ... so I would think you can change anything you want on the car with it. Getting rid of that damn check engine light was nice , too Cost .... whoever wants to know this I can't really give you an accurate amount since i got a differenct deal for being the experimental car, but I would just goto his website and contact him. He's pretty easy to reach about pricing. As soon as I or he has results from dyno , etc we'll post here. Looking good so far , though !
Quick Reply: Series II ECU Tuning
