5x100 wheels
Old 09-14-2009, 10:57 AM
Twiztog43's Avatar
CA 5x100 wheels
i was wondering is there something that would let me use 5x100 wheels? is there some kind of adapter?
the only thing i can find is the other way around which is 5x100 to 5x114
also is there any effects of using an adapter?
Old 09-14-2009, 11:09 AM
I8U
I8U's Avatar
For the money you would spend trying to convert them to work you could have just bought the right bolt pattern wheels to begin with.
Old 09-14-2009, 11:17 AM
Software Engineer
DarkLord7854's Avatar
This.
Old 09-14-2009, 11:19 AM
on his 3rd rx8
dozer's Avatar
^that
Old 09-14-2009, 03:07 PM
Twiztog43's Avatar
well i got the rims off craigslist for $140 so they weren't that much to begin with, but i was wondering if there was some kind of adapter
Old 09-14-2009, 03:34 PM
Hit & Run Magnet
kersh4w's Avatar
i believe there are spacers that act as adapters.
edit:
man, look what google shows up.
http://www.google.com/search?q=5x100...ient=firefox-a
Old 09-14-2009, 03:44 PM
He's as bad as Can
expo1's Avatar
Yes they do exist, at $45 each I don't think you will be using them. They also will greatly effect offset.
Old 09-14-2009, 04:43 PM
Redlined
Juansito's Avatar
http://www.projectnissan.com/shoppin...&idproduct=847 Price: $133.00
Old 09-14-2009, 05:06 PM
silent assasin
rodjonathan's Avatar
i have used em before but not this way around and honestly didnt feel any difference ... i used them to get our blt pattern rims on a gti ...
Old 09-14-2009, 09:52 PM
Twiztog43's Avatar
CA
what do you mean "I don't think you will be using them"?
oh and thanks to everyone who helped... i found a somewhat local company to do it custom for $140
its still cheaper than buying a new set of rims
tired of stockers
Old 09-14-2009, 10:27 PM
He's as bad as Can
expo1's Avatar
There is the cost for four of them, you might need to mod the fenders, you might be pushing your wheels out an inch or more. You might also will change the way the car handles with that much extra offset, that will need to be corrected.
Old 09-14-2009, 11:11 PM
Twiztog43's Avatar
CA
actually, i chose the thinnest thickness.... 19mm (0.75in)
i dont think i need to roll the fenders... especially since the rims are only 17"
Old 09-14-2009, 11:16 PM
He's as bad as Can
expo1's Avatar
Do you have the rims yet? I ask because not all 17" fit our cars. Most do, but some might not clear the brakes ( if you have a base A/T that came with 16's this is not a concern). I wouldn't commit to four adapters till you did a test fit. Can you get one and do a test fit?
Old 09-14-2009, 11:55 PM
Twiztog43's Avatar
wtf? really?
i was under the assumption that the MT at LEAST clears 17"
i knew that 16" wouldn't clear the brakes but are you really serious?
i do have the rims but how would i do a test fit if the bolts dont even line up with the bolt pastern on the rims?
Old 09-14-2009, 11:58 PM
Twiztog43's Avatar
heres a pic of the rims.... they look like they clear the brakes....
02-20-2019 05:16 PM
hufflepuff
05-30-2016 10:45 AM
snowrydr01
11-23-2015 09:40 AM
duworm
10-01-2015 04:57 PM
GranTouTou
09-30-2015 06:11 AM
Rate This Thread
Quick Reply: 5x100 wheels
