Right speaker going in and out... mostly out
Old 05-04-2009, 09:28 PM
M Theory: Code Red's Avatar
There doesn't seem to be a pattern for the speaker if I'm just idling, but while driving the passenger side speaker will sort of short out on me. It seems that there's a wire in there messing something up so I took the car to a shop and they removed the door panel and said that I have a bad amp. If I had a bad amp, wouldn't it just continue to be out and not work randomly?
I've tried to search for a code or something to put into the head unit and it trouble shoot to see if there are any problems that it recognizes.... but I can't seem to find them. Does anyone know of these or where I can find them?
Any help is much appreciated.
Old 05-04-2009, 09:36 PM
G3tR3DDY2GR3DDY's Avatar
no "codes" for the headunit , its not that smart
swap the speaker from passenger side to drivers side using the same amps and wiring in the doors, that narrows down the speaker
if no then swap amps only and see if it carries to the other side, narrows down the amp.
if still no luck then try resetting the headunit. i think just disconnecting the neg. battery cable is the easiest way
i have whatever you need to fix it if you wanna troubleshoot or need other help lmk
Jst4fun
03-05-2021 07:16 PM
09-30-2015 01:53 PM
Learners_Permit
09-27-2015 07:38 PM
Randolph Alvarez
09-14-2015 04:25 AM
Quick Reply: Right speaker going in and out... mostly out
