Pushing The Brake Caliper Piston Back In...
Old 03-10-2009, 06:35 PM
I don't buy Kool-Aid
DOMINION's Avatar
Lightbulb Pushing The Brake Caliper Piston Back In...
Gerrr so what do you guys use to push it back in with?
StealthTL told me to use this small box tool and screw it back in but I have one. But I think thats only when changing the back brakes right?
I found this but he said he use his hands:
http://www.installuniversity.com/ins...er_rebuild.htm
Is there a bolt I need to brake lose to get the caliper piston back in?
Old 03-10-2009, 06:59 PM
You can use a C-clamp...I usually use my fingers and the old brake pad....
The rears need the tool..you have to turn and push to get it to retract
If you open the bleed screw..it makes it easier
Old 03-10-2009, 08:53 PM
DOMINION's Avatar
For the front, I tryed with my fingers and a block of wood. But it would not go back in.
Ray told me to use a C clamp. Guess I will have to pick one up at Autozone.
Do I need to open the bleeder screw on the front too? or is that just for the back?
Old 03-10-2009, 09:07 PM
RX8 Club OG
Alucard's Avatar
You can try a pair of pliers also... put it between both pistons and open it up, that should send them back in..
Btw... You shouldn't have to bleed it, but if you have extra fluid and have no choice but to do it by hand it will make it easier.
Old 03-10-2009, 09:30 PM
Tea?
yokohamaboi's Avatar
you can do that or use a metal pipe and push it.
Old 03-10-2009, 10:22 PM
ndhoffma's Avatar
Ive only done the fronts... a C clamp works great. Glad to know Ill need a tool for when I get to the rears in the future
Old 03-10-2009, 10:35 PM
justjim
justjim's Avatar
Just get a large C-clamp and use the backing plate from an old set of worn pads to cover the piston (so as not to scratch the piston face with the clamp). Cheap, simple effective. Put one end of the C-clamp on the back of the caliper and the other end on the plate covering the piston front and squeeze.
Old 03-11-2009, 09:23 PM
DOMINION's Avatar
^Sweet I'm ready to do mine and my frinds Thursday.
Thanks guys!
Old 03-11-2009, 09:35 PM
Official Post Whore
pdxhak's Avatar
You can borrow the tool from autozone to turn the rears. They just need your CC. Also get a large c-clamp
Old 03-11-2009, 10:11 PM
ndhoffma's Avatar
Anyone know where you can buy the tool for the rears?
I think Id rather just have my own just in case
Old 03-11-2009, 10:24 PM
justjim
justjim's Avatar
They are available cheap at most chain auto parts stores, I got mine at
Advance Auto. Its a little cube with a different key on each side of the cube, one of which will fit the RX8 rears. The cube fits on a 3/8" drive socket wrench.
Old 03-12-2009, 05:09 AM
DOMINION's Avatar
^Yea I got that small cube key box looking tool thing lol at autozone for like $14 bucks. But you only need it if your doing the back pads. I'm just doing my front for now.
Old 03-12-2009, 10:00 PM
There is a DIY on this.
Open the master cylinder. Make sure you have room for the fliud to go up. If not use a turey baster and suck some fluid out.
Now you have the room AND the pressure is relieved. Use old brake pad and C clamp for front.
Needle nose for rear.
Old 03-12-2009, 10:51 PM
ndhoffma's Avatar
https://www.rx8club.com/showthread.php?t=68073.html
There is the DIY razz is referring to I think
Its not too clear on the needle nose pliers part though
Old 03-12-2009, 10:53 PM
Grasshopper
Jon316G's Avatar
I've always used pliers to retract the piston on the rear caliper.
Nothing wrong with that.
UHATEIT
03-31-2019 05:31 PM
seb16
09-15-2016 12:20 PM
jay_tibo
22
09-13-2016 08:10 PM
CMRine04
07-27-2015 09:46 PM
thewatcher101
07-27-2015 09:44 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
Quick Reply: Pushing The Brake Caliper Piston Back In...
