Box Opinions
Old 06-29-2008, 02:58 PM
malignant's Avatar
Box Opinions
I've been looking around and I see alot of people use the ZEnclosures box, but it's sealed is what I glean.
Now I'm getting a 12" Kicker L5, and I went over to Custom Sounds, and they quoted me $250 for a custom ported box for the RX-8, I was wondering whether you guys believe that is worth it, or if the sealed ZEnclosures for $150 would be a better buy. Cause I am really stuck between ported and sealed...not knowing what is better.
Old 06-29-2008, 03:45 PM
simplec's Avatar
It's as easy as this; a ported box will be louder, will be bigger and not as accurate as far as response time; a sealed box will be smaller, hit harder at lower bass notes and will reproduce the notes more accurately. With a 12L5 I'd rather have it in a large sealed box versus a small ported box going off of kicker's specs. Save yourself $100.
Old 06-29-2008, 04:47 PM
User and Abuser
firebirdude's Avatar
It's obviously not "as easy as this."
Old 06-29-2008, 04:52 PM
Never Blend In
nuke0907's Avatar
i have a kicker 12" L7 in a zenclosure box. its just enough airspace for it. you have the L5, so you shouldn't have any problems at all. i say save yourself the $100 and get the zenclosure.
TIP: put the box in the car first, then mount the sub. its not gonna fit through your trunk with the sub mounted, especially if you have the grill.
Old 06-29-2008, 08:03 PM
Asshole for hire
paulmasoner's Avatar
it will fit, I've done it twice. its just NOT EASY
Old 06-29-2008, 08:57 PM
simplec's Avatar
I simply weighed the pros and cons vs. two types of boxes firebirdude. So please raise the your B. S. flag- you're an idiot.
Old 06-29-2008, 09:04 PM
User and Abuser
To which you are incorrect. Increased low frequency extension is a prime characteristic of the vented design. But thanks anyway...
Old 06-29-2008, 09:23 PM
malignant's Avatar
Well, I listen to mostly rock and country, so I guess I'm gonna go with the sealed zenclosures then. If I just call the number, they will customize the box for the L5 right?
Old 06-29-2008, 11:21 PM
HEADTURNER
perks11's Avatar
yea thats what my buddy did, and it sounds great. i have two 10" memphis in a false floor box, looks sweet and sounds even better, but it all depends on what your going for, from my experience a custom box has almost always looked better for the shows, but if sound is all your goin for i would say the zenclosure would be just fine
Old 06-30-2008, 10:35 AM
malignant's Avatar
Ok so I'm all ordered up for my zenclosures box.
So the system is gonna be:
Kicker ZX750.1 Class D Mono Amp
Kicker 12 inch L5 Dual 2 Ohm
ZEnclosures sealed box
It should all be here this weekend, so I'm gonna try to get it installed then, which would be dope.
Old 06-30-2008, 03:21 PM
Never Blend In
nuke0907's Avatar
thats almost my exact setup excpet i have the L7. i'm also running it with a 2Farad capacitor. what is the power rating for the L5?
Old 06-30-2008, 03:50 PM
malignant's Avatar
600 watts rms, 1200 watts peak
Old 06-30-2008, 04:39 PM
Never Blend In
nuke0907's Avatar
slightly overpowered but thats ok. i think you will be happy with that setup.
Old 06-30-2008, 08:47 PM
malignant's Avatar
Hmm...overpowered? Maybe I shoulda gone with a L7 :-/
Old 07-02-2008, 11:07 AM
User and Abuser
You'll be fine.
New_Mazda_Guy
NW RX-8 Forum
09-19-2019 11:20 AM
yurcivicsux
192
09-12-2017 10:54 PM
Digitz0070
10-07-2015 12:43 PM
Danield97
09-30-2015 05:59 PM
Rote8
09-22-2015 03:43 PM
Quick Reply: Box Opinions
