blinking check engine light?
Old 01-11-2008, 05:34 AM
  #26
Faxie's Avatar
Originally Posted by swoope
where are you????
note.. you will get a cel on high speed runs if you are under .25 tank of gas...
coils dont get replaced for flooding plugs do..
Netherlands My tank was half full. And i meant the plugs, not the coils, sorry.
I'll try a high speed run again when i get the chance
Old 01-11-2008, 05:37 AM
  #27
make sure the plug wires are on all the way.. common problem...
Old 01-11-2008, 05:50 AM
  #28
Faxie's Avatar
Ok, i'll check that
Old 01-13-2008, 05:29 PM
  #29
Faxie's Avatar
Tried 2 times again.... 2 times the blinking light...
Now the CEL stays on.... dealer can read it out now lol :P
Old 01-18-2008, 08:38 AM
  #30
Faxie's Avatar
Well, went to the dealer, and it was a p0302, cilinder 2 misfire. Checked the sparks, and 1 spark was a bit corroded. Cleaned it, and changed it with the spark from the other cilinder.
If it happens again, and it's on cilinder 1, the spark's the problem. Otherwise the cable probably.
Old 01-18-2008, 09:13 AM
  #31
If it corroded why would you even think that might be the problem ?
go buy all 4 new ones and change them all out already.
Old 01-18-2008, 10:14 AM
  #32
Faxie's Avatar
Yeah gonna do that soon....car has to go through a required checkup in a month... every car older than 3 yrs must be checked every year in NL, don't know if there's something like that in the US....
Old 01-18-2008, 02:54 PM
  #33
tj7723's Avatar
had this happen to me a few weeks ago and then it happen again today and the light staied one. Took it to mazda and they texted it and said the coils were bad and gave me a rent a car till tomorrow to pick it up
Old 01-20-2008, 10:59 AM
  #34
hagar852's Avatar
I was getting CEL lights blinking also... Had the plugs replaced and didn't have any for 2 weeks...I was still getting CEL light.... braught it in again and the code spit out bad battery.. changed battery and cel went away for 2 more weeks....Then I got two in one day under heavy acceleration. Now I am bringing it back again... See what it is this time...
Old 01-20-2008, 08:58 PM
  #35
I don't buy Kool-Aid
DOMINION's Avatar
Exclamation
Originally Posted by HERO
So I was doing some high rpm highway driving for some routine carb deposit cleaning ^_^ and my check engine light started blinking for a good 3-4 seconds until i completely let off the throttle. Then all was well again with no check engine light. Does anyone know what a blinking light means?
Oh wow. I just had this one on my AT right before the wreck. Its your spark plugs. Take them off and look at them. You may have to change them.
-Gil
Old 02-06-2008, 06:51 PM
  #36
dizzy snake pilot
Ophitoxaemia's Avatar
had hesitation and blinking CEL for about 10 seconds. then it went away. the car drove normally at 75mph after that.
04 6sp 37K miles. its been damp and i had just washed the car (but thats not new).
have an appointment with the dealer tomorrow but warranty expired last september so think i will try changing the plugs first.
previously, for about a month thought there was sometimes hesitation when the car was first driven in the morning- wasnt sure. its not that cold here, 40's at night are about as cold as we get. but today it was obvious there was something wrong for a couple of miles before i floored it and got the blinking CEL.
Old 02-06-2008, 06:53 PM
  #37
it could be fuel pump, could be sparks, could be coils, could be plugs, could be alot of things. the worst is engine.
start with plugs first.
Old 02-07-2008, 02:05 AM
  #38
HERO's Avatar
yea, im giving my car a "tune up" (plugs, coils, motor oil, tranny/diff/brake fluid, coolant change) this weekend. Ill report if the blinking check engine light comes back on afterwards.
Old 02-07-2008, 09:28 PM
  #39
Finally a MT
lilring's Avatar
i have that same problem. have u got it fixed yet? please keep me updated
Old 02-07-2008, 09:53 PM
  #40
Originally Posted by mysql101
no, no, no! A blinking light means your door is ajar.
Hell my last car talked and actually told me the door was a jar.
87 Conquest by Mitsubishi
Old 02-08-2008, 12:34 AM
  #41
dizzy snake pilot
dealer said rear o2 sensor and coils on #1 were bad. i picked up the car and will install the parts this weekend. no more dealer, $130 to diagnose? getting a code reader too.
how come the o2 sensor and coils arent covered under the emissions warranty?
Old 03-09-2008, 07:51 PM
  #42
HERO's Avatar
After changing my coils, plugs and wires the blinking check engine light hasn't been back. Im pretty sure mine was due to the plugs. Looks to me like they should be changed every 20K miles, which im going to do from now on.
Old 03-10-2008, 08:36 PM
  #43
tim888tim's Avatar
Had the same problem last week where I was accelerating to get on the freeway and left it in 3rd to let the RPMs get up to clear out the carbon off the plugs. CEL flashed for a few seconds I lost power temporarily and then the CEL went out. A few minutes later it came back on solid. I took the car to the dealership the next day and they said I had low compression and would be getting a new engine. I have 04 MT with ~36K miles fortunately under warranty.
It sound like Mazda is having all kinds of issues with these engines.
Old 03-12-2008, 11:40 PM
  #44
and what was the code the cel put out???
Old 03-15-2008, 01:14 AM
  #45
tim888tim's Avatar
Rotor 1 misfire.
Also noted on the repair ticket was high oil consumption.
Old 03-15-2008, 01:45 AM
  #46
plug
plug wire
coil.
in that order.. high oil consumption is a good thing.. dont forget to run the crap out of it..
it is a good thing..
Old 03-21-2008, 11:54 PM
  #47
RWatters's Avatar
I just started having the flashing CEL problem today, right after the dealership replaced part of the negative battery cable due to corrosion. It'll only happen when I rev the car into the upper RPM range.
I guess I find it a hell of a coincidence that this problem happens right after the dealership touches my car. Of course it's out of warranty as well. I redlined the thing all damn day yesterday and it runs flawlessly, now every time I drop the hammer I get a CEL.
Bummer. I'm having Autozone run the code tomorrow because the hell if I'm paying Mazda another hour's worth of labor to screw my car up even more.
Old 04-10-2008, 11:18 PM
  #48
fahrfegneugen's Avatar
i had it in fourth going out on the highway tonight at about 90 or so and it wouldn't go past 104 or 7k and then I turned around to go back home and gunned it and the CEL started blinking and then turned off. Full tank of gas too... and I just got my recall done, lol. This seems to fit the description of a misfire though, should I be looking at replacing the plugs (never done it, need help maybe)? I guess I better pull them out and look at them.
I thought my engine was going out! This thread saved my sanity.
Old 04-10-2008, 11:50 PM
  #49
Haze's Avatar
Could have something to do with ECU not having enough time to learn the new maps from the recall.
Old 04-10-2008, 11:56 PM
  #50
^thanks for the idea. I will go get the code tomorrow.
Quick Reply: blinking check engine light?
