How much vibration is 'normal'?
Old 03-24-2007, 03:42 PM
Imidazole's Avatar
I have a 2004 M6 RX-8. When sitting at idle, my drivers chair vibrates. The shifter vibrates (pretty normal), and you can feel the whole car (and hear it) vibrate to the idling engine. The door handle, you name it.
Rev it up some, all gone.
Is that normal? Is it possible that I might want to have the dealership check the motor mounts? Or do our 8's vibrate a bit more than 'other cars'?
Old 03-24-2007, 03:51 PM
I would check the mounts...they say that the 3K stutter is the test for the MT...but mine idles like **** with the broken mount.
The damn thing has been BO'd for over a month
Probably could use new plugs/coils too
Old 03-24-2007, 04:15 PM
ummm. There is a Search button up there?
I cant believe you have 321 posts in here and still dunno about the Wonderful Search Button.
Old 03-24-2007, 05:15 PM
Imidazole's Avatar
Thank you for all of the help.
Old 03-24-2007, 05:17 PM
mysql101's Avatar
you should always feel it in the shifter. you should not feel it anywhere else.
at idle, nothing should move, you shouldn't feel it in your chair, on the peddles, or in the door...
if you have any doubts, go to your mazda dealer and get a test drive from a new car
its usually the motormounts going that cause the vibration.
RevMeHarder
08-16-2023 06:23 PM
tommy26Germany
09-29-2015 10:33 AM
Jb4ker96
09-27-2015 10:06 PM
RAE008
09-19-2015 02:24 PM
patriotjj
09-13-2015 08:09 AM
Quick Reply: How much vibration is 'normal'?
