Need help on Rotors
Old 02-27-2007, 03:00 PM
PWRCLOSER's Avatar
Need help on Rotors
Dealer told me I need new rotors(I do alot of 90-100mph hwy driving) and they want $600. for the job . I told them no thanks. Can anyone recomend any good aftermarket rotors? Im thinkin I want slotted \ drilled. any help is appreciated.
Old 02-27-2007, 03:05 PM
SOVINE's Avatar
I got a pair of brembo front rotors for around $340. I didn't call the dealership about it because I thought if I have to replace the rotors I might as well get something besides the OEM rotors.
Old 02-27-2007, 03:06 PM
Extraordinary Engineering
DarkBrew's Avatar
http://www.rx7store.net/category_s/271.htm
Old 02-27-2007, 03:51 PM
www.tirerack.com
Old 02-27-2007, 03:53 PM
if u need to replace all 4 (which I seriously doubt) its gonna cost you like maybe 500 bux(depends on the brand/slotted/drilled)
Labor, 1 hour should be able to replace all 4.
you do the math.
Old 02-27-2007, 04:01 PM
meow
llzjayarzll's Avatar
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/looking-better-rotors-110208/
my thread =x
Old 02-27-2007, 04:22 PM
Vroom
Endor's Avatar
Why does 90-100MPH driving necessitate new rotors? Constant hard braking to avoid rear-ending cars that are doing the speed limit?
Old 02-27-2007, 04:40 PM
Shock and Awe
NoTears316's Avatar
I was just thinking the same thing.
Old 02-27-2007, 05:16 PM
Registered Tracker
BlueRenesis82's Avatar
vtec just kicked in y0
Old 02-27-2007, 05:32 PM
always filling [the c]up
Cody Red's Avatar
www.racingbeat.com
-Cody
Old 02-27-2007, 05:43 PM
Baned
rglbegl's Avatar
Are you sure the dealer is not just trying to make a buck?
Have you been pounding your brakes? You can drive 100mph forever and NEVER use your brakes. But STOPING from 100 to 0 super hard will do damage. ( many stops, not just one ) Do you really need rotors, or do they just need to be turned? Have you been doing a lot of braking? Do you deal with traffic a lot?
Rotors are hard to mess up. Mine last for a LONG time, and I drive fairly hard.
When you drive . . . does the steering wheel shake? When you hit the brakes, do you feel the car pulsating? ( warped rotor pulsate, not ABS pulsate )
Old 02-28-2007, 06:00 AM
the WANKEL made me do it
Mazda-Rati's Avatar
Driving 90-100mph has nothing to do with your brakes. It's hard to believe it's your rotors unless you're really hard on them. sounds like your tires are out of round or they just need balanced. An alignment may help.
Old 02-28-2007, 04:27 PM
MichaelBrown's Avatar
"VTEC? Man, I don't even got valves!" - BEST QUOTE EVER!
jamespond24
12-01-2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
10-14-2015 12:29 PM
Eliseo Esquivel
09-30-2015 08:28 PM
pjwermuth
09-28-2015 11:36 PM
coolcars44
09-24-2015 05:47 PM
Quick Reply: Need help on Rotors
