Petit Raceing PCM-AN Recal Kit w/ EFI Dude Logger device
Old 08-21-2010, 07:44 PM
hirev8's Avatar
Guess this is the equivalent to the Access Port but can any one give any feedback on this device? Thinking about buying is a bit pricey (599) but they state 11 to 14 % power and torque gains.......Anybody???
Old 10-19-2010, 01:36 AM
Demifiend's Avatar
I think those are just internal components for the actual supercharger system.
Old 10-19-2010, 02:09 AM
Londons Yellow Peril
california style's Avatar
No the ANP kit is a combination of a catback + optional hiflow cat and K&N panel filter (or intake system) combined with an EFIdude logger /reflasher.
Pettit say that just doing a reflash alone is fairly pointless.
Their reflash adjusts the fuel mapping a little for some more power, and add increased high load oil injection and turns on the fans earlier too.
Old 10-19-2010, 02:50 AM
3-wheeler
Flashwing's Avatar
I'd say that is far from pointless.
Old 10-19-2010, 06:25 AM
Hehe, true...., I guess you can get the "added benefits" but most people want a bit of performance too.
It all depends on how people want to spend money....
Old 10-20-2010, 06:04 PM
Demifiend's Avatar
Do you think that something like that is worth it then? I had been looking at superchargers especially theirs for quite some time considering I feel like it would be the best FI to do with the Renesis. Would something like that work on a stock car or would you need to add the supercharger also?
Thanks in advance.
Old 10-20-2010, 07:22 PM
I'm curious about what parameters led you to that conclusion.
Old 10-20-2010, 08:14 PM
Received 2,025 Likes on 1,649 Posts
.... assuming a non-vehicle specific flash just happens to jive with your particular vehicle parameters ....
So its the same as a Racing Beat flash, rather than an AP since it cannot be tuned by anyone other than Petit to be vehicle specific
Old 10-20-2010, 08:30 PM
3-wheeler
Flashwing's Avatar
You're correct, there are a few assumptions there.
I'm still surprised people are trying to find an "equivalent" to the accessPORT. There is not any flasher device for the RX8 that has the robust nature of the AP for the cost.
An equivalent to the accessPORT would be a stand alone management system but would cost double, tripple, or more than the accessPORT unit. Much of the stand alone technology is also seriously older hardware than the RX8 PCM which is a powerful device.
And pricey? I think you need to shop around for what the costs of other tuning hardware is. Almost all of the good stuff starts above $1,000 and then you need to wire it into the car and find someone who can tune the car for you unless you want to do it yourself.
The only thing better than the AP is a device that tunes the car itself. Everything else either provides much less function and robustness or greatly exceeds the cost of the AP.
Old 10-20-2010, 09:07 PM
The advantage of a "proper" stand-alone over the AP is that for a pure performance application (no emissions) you can tune in the engine more readily because all the OE software hocus pocus anomalies are eliminated. Proper as in MoTeC, but it requires some other supporting changes such as switching to an FD3 alternator etc. Changing to the S2 4-injector lower intake manifold further simplifies the process. The disadvantage as you mentioned is the cost, which is way more than triple, or even triple-triple, in that case The never ending compromise of life ...
Old 10-20-2010, 10:31 PM
3-wheeler
Flashwing's Avatar
Exactly. Stand alone systems offer an amount of customization and even information gathering that is WAY beyond what the accessPORT will provide. I've not worked with MoTec systems at all but had an opportunity to observe the setup on Chris Rado's time attack Scion and the amount of data that could be gathered from the car's logs was staggering.
But naturally that all comes at a high cost and also requires extensive experience with both the setup and execution of the hardware. It's one of those "...if you have to ask" things.
I feel like I'm beating a dead horse with this but I just have a hard time understanding the mindset that there is going to be something just as good out there for the cost when there are probably hundreds of pages devoted to the accessPORT on this site.
I know there are individuals who have gone with other products either because they feel they have to be different or to spite Mazdamaniac for one reason or another.
Even the thread that popped up about installing the Megasquirt on an RX8...it baffles me to spend all that money and time to produce a result that is either the same or less than what can be achieved with the AP. The attitude doesn't seem to be an intent on learning but instead to reinvent the wheel. Engine swaps or radical changes to the car I can understand but still...
I approach everything in this community from the perspective of cost vs. benefit since 99% of BHR's customers do the same as have I when it comes to performance modifications. I just don't understand spending more to get the same or less.
Old 10-21-2010, 02:40 AM
Demifiend's Avatar
From what I've read on here and the way that I understand the Renesis to work Turbos can build up a lot of back pressure that can blow out the side exhaust ports if not tuned properly.
I do want to know more about FI. If I were to ever do it, I'd want to do it the best and most reliable way, so if you have any advice, I'd appreciate it.
Old 10-21-2010, 03:05 AM
3-wheeler
Flashwing's Avatar
Much of the anti-turbo posts were done in an effort to squash a competitive product and not because someone is trying to do turbo lovers a favor.
Old 10-21-2010, 09:29 AM
to answer your question Demifiend, the ANP reflash device is the same tool Pettit use to reflash the cars using their supercharger kit, so you could in theory use it for an NA reflash, then if you got the supercharger kit later, you would already have a bit of it....
as for turbos v superchargers, its one thing that goes back and forth a lot, with 1% useful info and 99% spurious reasoning, flaming & insults on every thread with it in usually..... 8(
Old 10-22-2010, 12:30 AM
I feel like I'm beating a dead horse with this but I just have a hard time understanding the mindset that there is going to be something just as good out there for the cost when there are probably hundreds of pages devoted to the accessPORT on this site..
go figure
https://www.rx8club.com/good-guy-bad-guy-74/bad-guy-racing-beat-205911/
Old 10-22-2010, 01:48 AM
3-wheeler
Flashwing's Avatar
Originally Posted by TeamRX8
Yep, exactly.
Old 10-22-2010, 01:51 AM
more often than not it has nothing to do with MM, just like the way people still can't follow the instructions about how to follow the instructions for following the instructions ...
if I had wanted to really pop his bubble I would have told him that I've seen unported motor dynos that bury the ported RB dyno sheet ...
Old 10-22-2010, 07:55 AM
FI by Pettit-BHR-Cobb AP
Phil's 8's Avatar
Please do not start another s/c vs turbo slug fest......
Old 10-22-2010, 08:05 AM
olddragger's Avatar
Now Team--you know people know what they are doing
A lot just dont want to listen, even when something real is being said.
OD
Old 10-22-2010, 11:16 AM
This is about PCM calibration, not the various puffers.
Old 10-22-2010, 11:45 AM
Phil's 8's Avatar
I was enjoying the banter about the various ways to calibrate the PCM and then it appeared it was going toward a "puffer" discussion. Jeff knows I don't how to properly tune my own PCM but that does not keep me from being interested in how others do it and the different ways to do it.
Old 10-22-2010, 12:27 PM
It's only a matter of time before one side tells the other side to go fugu themselves ....
Hunterkelley24
Series I Engine Tuning Forum
06-14-2022 08:32 AM
Tweaked Tay
09-25-2015 07:54 AM
lazi
13
07-10-2007 01:06 PM
PUR NRG
04-11-2005 04:55 PM
Quick Reply: Petit Raceing PCM-AN Recal Kit w/ EFI Dude Logger device
